Cutting Fence Post Caps - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 09:15 AM   #16
Rewards Points: 2,212
what they said
mae-ling is offline   Reply With Quote
Old 07-12-2012, 10:12 AM   #17
Rewards Points: 518
Originally Posted by hand drive View Post
if you have to rent a saw, how about renting a miter saw. set up a bench and set the saw to 45 degrees. flip the post for each cut, done.
The posts are already set, they are being cut in place.
n0c7 is offline   Reply With Quote
Old 07-12-2012, 10:16 AM   #18
Rewards Points: 518
Originally Posted by kwikfishron View Post
Use a 7 saw and finish with a Sawzall or hand saw as previously mentioned.
That can be a dangerous cut if your not well familiar and comfortable with a beam saw.
I don't want to sound ignorant but if I'm running the saw against a jig how is it any more dangerous than using a 7 1/4"?
Old 07-12-2012, 05:36 PM   #19
kwikfishron's Avatar
Rewards Points: 998
Those big saws have a lot of torque and are heavy, close to 20lbs for a 10” and 30 for the 16”.
You’re holding it up at face level trying to make precision horizontal cuts, if the saw binds up I hope you’re capable of controlling it, because you sure can’t just let go.
Being confined to a jig actually increases the chances of binding up in your case btw.
I don’t know you, your skill level or anything else but just asking these questions has me concerned.
I certainly would never hand a beam saw to a rookie and send him loose on what you’re wanting to do.
Others here say go for the big saw and I’m not saying not to, just be aware.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
mae-ling (07-12-2012), PaliBob (07-14-2012)
Old 07-14-2012, 12:52 AM   #20
Rewards Points: 518
I appreciate your concern for safety. I have 8 years of DIY experience in too many areas to mention, jack of all trades type of thing. I have never needed a circular saw larger than 7 1/4" until now since I usually have worked with 4x4 lumber.
I rented the 10 1/4" Makita and I have to say while it was heavy, I actually felt like I had more control since you HAVE to use two hands on it compared to the 6 1/2"'s and 7 1/4"s out there. It did the cuts I wanted and I'm satisfied with the results.
The Following 2 Users Say Thank You to n0c7 For This Useful Post:
mae-ling (07-14-2012), PaliBob (07-14-2012)
Old 07-14-2012, 01:01 AM   #21
Sweet ! It might be the glare of the sun on your photo , but I don't see the nipple .
CopperClad is offline   Reply With Quote
Old 07-14-2012, 01:06 AM   #22
Rewards Points: 518
funny guy. This saw actually went a bit deeper and squared it off it seems.
Old 07-14-2012, 01:50 AM   #23
Well I'm not a circular saw scientist??? How far will a 10'' saw go on a 25 degree angle? I don't own a 10'' circular saw, I just remember using one cutting 4x4 post in one pass. Was it too big of a saw for the job? Knowledge is power, and I'm all about gaining it.
Old 07-14-2012, 02:21 AM   #24
Your top is now untreated, some clear stain or sealer from the weather may be in order, nice cuts btw! Did you use a guide nailed to the posts or freehand?
Klahti is offline   Reply With Quote
Old 07-14-2012, 02:25 AM   #25
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Thanks for the pics and for the feedback.
What did you use for a saw guide?
Clamped on speed square?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 07-14-2012, 02:37 AM   #26
Clamped on speed square would work.. But you would have to move it 4 times per post.. I would have built a 2x4 box to fit over the 6x6 post and had 2 bessey clamps angled towards the bottom and not have to move anything for each post. yeah.. what jig did you have ?
The Following User Says Thank You to CopperClad For This Useful Post:
Old 07-14-2012, 10:50 AM   #27
Rewards Points: 518
I'm retreating all of them with green end cut today.
I built a jig out of 2x2s which I slid down the post, leveled and screwed into two sides. The distance from the edge of the fence to the beginning of the angled cut is supposed to be 4" so by using the 2x2s(actually 1 1/2") and adding the width of the saw guard being 2 1/2" I got my 4".
Klahti (07-14-2012), PaliBob (07-15-2012)
Old 07-15-2012, 08:00 PM   #28
Rewards Points: 518
The saw is labeled as a 10 1/4". At 25 degrees it measures 3 1/2" from the edge of the guard to the tip of the blade. At 0 degree's it measures 3 3/4".
mae-ling (07-15-2012), PaliBob (07-15-2012)
Anchoring Fence Posts With Metal Post Base? Boiler98 Building & Construction 0 07-08-2012 11:23 AM
How to install a metal fence post DEEP into the ground? boba7523 Building & Construction 14 09-20-2011 06:34 PM
How to replace a loose fence post preciouschristy Building & Construction 2 05-14-2011 05:06 PM
concrete anchor for cedar fence post matt76 Landscaping & Lawn Care 0 06-25-2010 08:04 AM
Fence Post on Concrete rjschwar Building & Construction 14 04-30-2010 01:02 PM
