Cutting Durock - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2008, 06:58 PM   #1
cutting Durock
What is the best and easiest way to cut Durock? Is it like drywall where you score and snap, or is there more to it than that? Thanks.
hammer is offline   Reply With Quote
Old 03-10-2008, 07:09 PM   #2
I use a 4" grinder with a dry diamond blade. Makes a mess but it's very quick. And, as with Atlantic's post, the dust is some nasty stuff, so I always try to cut it outside and wear a mask. I too have one of those carbide knives, but I find it too slow to use. But, if you only have a few sheets to cut it may be better to use.
jerryh3 is offline   Reply With Quote
Old 03-10-2008, 07:28 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
We use a razor knife, score and snap. We also use a 4" grinder with a masonry wheel when we need smooth cuts, but like the last jerry3 said, it gets dusty
USP45 is offline   Reply With Quote
Old 03-10-2008, 09:30 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Use a cement board cutting knife. It has a some-what "T" shape to it. The "T" ends are carbide tipped and look like a circular saw carbide tip.
Example: http://www.askthebuilder.com/Cutting...rd_Video.shtml
You want to keep the dust down, as much as possible, when cutting, due to the silica dust.
MSDS Sheet (Material Safety Data Sheet):
http://www.usg.com/navigate.do?resou...ment_Board.htm:
CARCINOGENICITY CLASSIFICATION OF INGREDIENT(S)
"All substances listed are associated with the nature of the raw materials used in the manufacture of this product and are not independent components of the product formulation. All substances, if present, are at levels well below regulatory limits. Portland cement is not listed as a carcinogen by NTP, OSHA, or IARC. It may, however, contain trace amounts of substances listed as carcinogens by these organizations: crystalline silica, hexavalent chromium, lead compounds, mercury compounds, nickel compounds, and possibly other chemicals. See Section 11 : Toxicology Information for detailed information"
Silica (Health Effects): http://en.wikipedia.org/wiki/Silica
More installation instructions: http://www.askthebuilder.com/Cutting...rd_Video.shtml
- Build Well -
Old 03-11-2008, 01:54 PM   #5
so-elitecrete
Rewards Points: 150
what a GREAT tip,,,
never event thought using a tile scribe as we've always got 4" grinders on the job,,, THANKS, bud ! ! !
so-elitecrete is offline   Reply With Quote
Old 03-11-2008, 03:39 PM   #6
Personally, If I have to install it.
I use:
Strong Fan ventilation to the outside.
Very good cannister-type dust masks &safety glasses.
A carbide tip skill saw blade, that gets tossed after the job.
A carbide-dusted jig saw blade, for detailed cuts.
Some saw horses.
A chalk pen for marking.
- Build Well -
Old 03-11-2008, 04:52 PM   #7
so-elitecrete
Rewards Points: 150
since we use 'em,,,
for dec conc engraving, etc, they're often equipp'd w/dust muzzles hook'd up to wet/dry vacs,,, no dust.
Cutting Duct ADKstorm HVAC 10 01-23-2011 01:30 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 09:38 AM
Bathroom - Durock murphy54 General DIY Discussions 12 02-10-2008 09:12 PM
Painting the inside edge of cutting board slots 1655graff Painting 8 01-28-2008 07:51 PM
durock on studs, durock screws johnny331 Remodeling 2 06-13-2007 05:49 AM
