Cutting A Door Into Basement Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 02:42 PM   #1
Cutting a door into basement wall
I have a 48" The concrete is about four feet high and the window sits on the concrete wall. I plan to remove the window and have a professional cut out the concrete opening for the door. The siding comes down about a foot below the top of the concrete wall. The question is how big an opening for the door. Being told 41.5 inches to allow for the door framing to be attached the concrete opening on both sides? How do I cover the gap where the brick mold is attached to the siding but not the concrete as the siding is over the concrete?
klaffey is offline   Reply With Quote
Old 04-19-2011, 03:16 PM   #2
Rewards Points: 5,336
The opening for the door would be based on the size of the door you would be putting in. The door frame should not be attached to the concrete. You should be installing a wood frame aroung the prehung door. So the rough opening would include the doors requirements and the framing material.
You will remove all the siding around this unit.
After the door is in and the exterior trim is applied, you will reside to the new opening.
Ron
Old 04-19-2011, 03:18 PM   #3
Concrete & Masonry
Rewards Points: 470
Sounds like a 36" door, which has a rough opening of 38.25-38.5" plus 1.5" per side (3" total) for 2x lumber attached to the masonry equals 41.5".
Why not get rid of the brick mold and just use some form of 1x4 or the like?
jomama45 is offline   Reply With Quote
Old 04-19-2011, 03:45 PM   #4
That will work thanks! The door will be exposed to the outside until a garage addition covers it later this year. It will then be an interior door.
Old 04-19-2011, 04:01 PM   #5
Then you'll need to install a fire rated door.
Ron
Old 04-19-2011, 04:37 PM   #6
Will do! Thanks!
Water coming in over the top of the wall in the basement michaelduke Building & Construction 5 03-06-2011 03:13 PM
Basement floor leaking after wall repair unfortunateluck Building & Construction 6 02-15-2011 07:05 PM
vapor barrier on basement pony wall hobbs in vanvouver Building & Construction 3 02-13-2011 09:07 AM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
Best way to cover over brick wall in basement? tigereye Remodeling 4 04-14-2009 11:24 PM
