Old 11-04-2012, 05:22 PM   #1
Solutions (handyman)
cutting curves in vinyl siding
I am refacing a wall at the front of a quanset. Where the front wall meets the sides I will have to cut to match the radius of the structure. Any suggestions on the best way to cut the curve? I could use a knife of tin snips but am wondering about a jig saw. Pros & cons?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 11-04-2012, 05:44 PM   #2
Pictures would help as this would give us a better understanding of your situation then we could give you a solution or advice on how to tackle situation.
epson is offline   Reply With Quote
Old 11-04-2012, 05:48 PM   #3
Moderator
kwikfishron's Avatar
I've never cut VS with a jigsaw before but I'm sure it would work just fine as long as you use the finest tooth blade you can find.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
Old 11-04-2012, 06:53 PM   #4
Davejss's Avatar
A good pair of siding snips would make a clean accurate cut. I've also used a Makita cordless trim saw with a 3-1/4" blade, but it has to be warm out or the siding chips quite a bit. I always end up going back to the snips.
Davejss is offline   Reply With Quote
Old 11-04-2012, 08:48 PM   #5
As cold as it must be getting up there by now you'll be lucky to even be able to use snips, but that would be the best way.
Old 11-04-2012, 09:13 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
i use malco siding snips. their easily the best snips available for siding. just about any chippy who does high end exterior work carrys em.. much easier to use than aviation snips and they make a longer cut reducing furry cuts
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (11-04-2012)
Old 11-05-2012, 09:56 PM   #7
firehawkmph's Avatar
+1
Mike Hawkins
firehawkmph is offline   Reply With Quote
DIY - Vinyl Siding over Cedar Shakes rebelranger Remodeling 9 08-02-2012 10:47 AM
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
Vinyl Siding Help Needed swiederin Building & Construction 4 10-24-2011 10:02 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
