Cutting Cultured Marble - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-22-2010, 11:54 PM   #1
Question
cutting cultured marble
I would like to see if anyone knows what would be the correct blade or tool to cut cultured marble .
redbird_1967 is offline   Reply With Quote
Old 12-23-2010, 04:57 AM   #2
Rewards Points: 4,638
DIAMONDS are marble's best friend you can get away w/any apron store blade for a 4" grinder cutting dry,,, just be sure you cut safely & make use of your dry vac as there'll be tons of dust
a pro would use a blade that's relatively got a harder segment ' bond ' ( matrix ) as marble's soft compared to granite which would req a softer bond segment,,, but that's all ' zen ' cutting - unless you cut a lot, its not expensive to use up the cheap blades
Old 12-23-2010, 06:21 AM   #3
Yep, diamond would be my choice, but a good carbide blade will work. It won't cut much after that, however.
The Following User Says Thank You to Just Bill For This Useful Post:
oh'mike (12-23-2010)
Old 12-23-2010, 10:03 AM   #4
Household Handyman
Rewards Points: 1,408
Actually I found another cutting method: I use a "die grinder" powered by compressed air and have a four inch (4") x 3/32" thick abrasive wheel mounted on it. I know--everyone doesn't just have one of these lying around, but I do. I have found that this cuts cultured marble very clean, although it makes lots of dust. I have even cut one curve with this set-up. Just my way, David
Old 12-23-2010, 11:49 AM   #5
Experienced
Jackofall1's Avatar
Well - "RedBird" - Ask yourself if any time in the future if you plan on trying your hand at laying some ceramic or porceline tile, if the answer is yah I think I might try that someday, go out to one of those big box stores and buy yourself a wet saw, could be had for <$100 bucks and then you have one in your arsenol of weapons for the future.
Old 12-23-2010, 12:25 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can cut cultured marble using a "masonry" abrasive blade in a circular saw also. If this is a vanity top, it's best to turn it upside down to cut it. Have someone right there with a vac to collect the dust. Cut all the way through the first time.
XXX
Old 01-03-2011, 12:06 PM   #7
Thanks for all the replies. I ended up going to the hardware store and picked up a 4" dry cutting diamond blade for 10 bucks. It cut great but the dust was everywhere. I used a shop vac and had the overhead kitchen fans on but there was still a lot of dust. The whole excercise was to replace a glass counter top stove, that had been cracked, with a new one. Although the outside dimensions were the same the hole needed to put the stove in was one inch bigger in both the vertical and horizontal dimensions. Thanks again for the assistance.
Old 03-12-2011, 08:46 AM   #8
tomson2101's Avatar
Cultured marble like natural marble should be cut with a diamond disk. Although many like a quick dry cut ... in truth it should be a wet cut, the disk lasts a bit longer and the cut comes out perfect. It's very common for some types of marble based material to chip the edges while cutting so you should be careful.
tomson2101 is offline   Reply With Quote
painting cultured marble debden55 Painting 7 02-27-2014 11:32 AM
Granite tile over cultured marble? stage kat Flooring 3 05-07-2011 02:46 PM
Anyone ever put formica over cultured marble? b_corwin General DIY Discussions 4 01-20-2010 01:35 PM
Refinishing cultured marble counter? MBritton General DIY Discussions 2 08-21-2009 06:05 PM
Cutting 1/2" Marble? Bob_Alias Remodeling 1 09-06-2008 11:30 PM
