Cutting Concrete Foundation For Door, Is It Safe? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-30-2010, 08:24 PM   #16
Rewards Points: 1,910
Originally Posted by Scuba_Dave View Post
Not always true on older houses
I have floor joists landing on the top of my basement windows without any header
It's possible that the header is raised - i.e. what appears to be rim joist was actually sized to function as a header.
Old 06-30-2010, 10:05 PM   #17
Did anyone catch the fact his property is on a slope? You should consider drainage as part of this design so you don't end up with water issues.
Bldg 2 Spec is offline   Reply With Quote
Old 07-01-2010, 05:10 AM   #18
Rewards Points: 4,732
as sketched & w/your information, i'd do it in my home,,, just ck w/your bldg inspector 1st,,, good luck !
stadry is online now   Reply With Quote
Old 07-01-2010, 10:10 AM   #19
Concrete & Masonry
Rewards Points: 616
One more vote to go ahead IF the top of the current window opening won't be altered. Ask the guy who will be doing the concrete cutting for his pro-opinion as well.
jomama45 is online now   Reply With Quote
Old 07-01-2010, 07:56 PM   #20
First thank you all for your comments; so far it appears that there are no major issues to cut the concrete below the existing window as window’s header already supporting the load above it. I have no worries for drainage; the slope angle decrease dramatically few feet down from the window so I believe that will work out. The only thing that I am concern about is the shear force of tons of soil that pushes against the concrete wall and foundation, in other words would it be ok to interrupt the continuity of concrete wall which is constantly under pressure.
Mossiliza is offline   Reply With Quote
Old 07-01-2010, 08:23 PM   #21
You dig out the dirt there isn't any pressure against that wall
You will need to build a proper retaining wall to hold back the dirt from the slope(s).
And if you will be stepping up to get out of the basement area you will need to make sure you have proper drainage
The drawing shows cutting out below 2 windows ?
How wide of an area are you cutting out ?
Old 07-03-2010, 06:57 PM   #22
So I decided to go ahead and get some to do this project, but yesterday I noticed the gutter drainage is passed from this side, so here is my question; according to standards how deep in ground is this drainage pipe? I was told by a contractor that drainages are usually passed beside the footer, is this true and if it is true does it mean that I can dig 5 feet without interfering with the drainage system?? Attached is a drawing of how the situation looks like…
Old 07-04-2010, 01:01 PM   #23
Registered User
Rewards Points: 526
I would consult a Structural Engineer and/or a soil professional to be safe. They would check the soil, figure the pressure, calculate the required remaining wall after the proposed cutting to see if it is possible or give some professional suggestions for the safety and liability issues involved. Taking into account the concrete wall thickness, steel placement and size, footing width and depth, steel there, etc. A retaining wall as someone suggested would not work in this case as the side (proposed wall) is supporting the end (corner) of the back wall--- the shear pressures there could be tremendous. I wouldn't give you information just for the safety and liability involved, and I am not a S.E.
Please get a permit, to keep you and your family safe......
Be safe, Gary
Old 07-05-2010, 01:33 AM   #24
Agreed !! Get an engineer. A retaining wall holding back 8 feet of dirt is nothing to guess at.
Nailer is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
New Foundation: Minimum height of concrete above openings axiom10 Building & Construction 2 04-11-2010 10:26 PM
how safe to dig near concrete slab Roberta-mos Building & Construction 6 06-10-2009 04:58 AM
Concrete Flooring in Safe Room GorillaBoze Building & Construction 3 03-05-2008 03:01 PM
When is it safe to walk on fresh concrete? chaddihimself Building & Construction 4 08-13-2007 12:34 PM
