Cutting Ceramic Tile - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 09:20 AM   #1
Rewards Points: 22
Cutting ceramic tile
I have a masonary blade for my chop saw used to cut brick. Can I use that blade to make a cut on a 1/4" thick piece of ceramic tile?
Ronnie1a is offline   Reply With Quote
Old 05-30-2012, 09:55 AM   #2
I personally would use a wet saw, it makes clean dustless cuts. ( it costs about $50-$99 small table saw style ... don't get the plastic one, they are real cheep quality) .... you can always sell it once you are done if you no longer want it. or just use a tile cutter that does a good job on ceramic tiles.
jlazer is offline   Reply With Quote
Old 05-30-2012, 12:39 PM   #3
You most likely will get lots of chips on the edge. Depends how many you have to cut. If its just a few they make a handsaw or you can get a blade for grinder. Many times you cut tile by scoring and snapping it like glass. You can rent the scoring tool very cheap and a wet saw for a bit more.
bill01 is offline   Reply With Quote
Cutting ceramic tile with a scroll saw? HandyHunter Flooring 14 12-06-2011 08:56 AM
new ceramic tile over 12x12 ceramic danthebuilder Tiling, ceramics, marble 4 08-09-2011 12:03 PM
ceramic tile walls with mastic Boris100 Building & Construction 2 02-14-2011 09:39 AM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 07:58 PM
Want to change ceramic tile to granite tile smart2surf Flooring 3 06-24-2009 08:11 PM
