Cutting Band Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-30-2011, 05:07 PM   #1
Cutting Band Board
I am needing to access a section of my house between floors. Access from the interior isn't possible so I need to remove about 2 to three feet of the band board. Or make a cut to remove the bottom half of that portion of band board at the very minimum. My question is...is this structurally safe to do so. I could then re nail the section in place afterwards and replace siding. Any help on this would be appreciated....thanks.
ba2800 is offline   Reply With Quote
Old 05-30-2011, 05:10 PM   #2
Framing Contractor
Rewards Points: 60
You should be ok. Just nail every thing good when you reinstall it.
sixeightten is offline   Reply With Quote
Old 05-30-2011, 09:02 PM   #3
Custom Home Builder
Try to cut halfway on the joists just to be on the safe side.
thomasjmarino is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
cutting plywood panels w circular saw Klawman Carpentry 11 12-11-2009 02:40 PM
Cutting in to baseboards? windowguy Painting 9 02-08-2009 10:20 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
