Cutting Back Floor Joists For Brick Ledge - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2012, 07:12 PM   #16
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 1,630
Originally Posted by jomama45 View Post
If they where for lateral load only, they wouldn't need a nut, and they wouldn't be a small bolt. So, yes, they are indeed used as a hold down. You really should check with your own local building codes, but they need to be tied to a grouted pilaster here, and it's just plain good practice. It will also add likely much needed strength to your existing foundation walls..........
Thanks.
My intent was not to imply I would not be anchoring the sill plate.
I already know code here and for that matter, probably all of Canada and the States requires anchor bolts.
My question was simply a question. Just curious about what the bolts purpose is. My house has been standing on its foundation since 1967 with nothing holding it in place that I can see.
What I do need to do though is to find out what the load bearing value of my soil is to see if the 16" footing can handle a two storey house with brick veneer. I believe I need 3000PSF for my footing size and the intended application.
Anybody know how they test this?
123pugsy is online now   Reply With Quote
Old 10-15-2012, 08:44 PM   #17
Concrete & Masonry
Rewards Points: 636
The times I've seen the soil under footings tested is via a tool that looks like a long slide hammer that rests on the soil. They drop the "hammer" portion X mount of times and measure how deep the rod penetrates the ground, which gives them the values for their evaluation. Not sure how you'd do it on an existing foundation w/o digging it up, or how you'd verify that the footing is only 16" for that matter.............
jomama45 is offline   Reply With Quote
Old 10-15-2012, 09:16 PM   #18
123pugsy's Avatar
Interesting.
The footing sticks out 3" beyond the 10" blocks. I would imagine its 3" on the inboard side as well making it 16". I seen this (the outside only) when the foundation was being waterproofed. I didn't think about getting it tested at that time.
Old 10-16-2012, 01:18 PM   #19
123pugsy's Avatar
I talked to the soil engineer. He needs me to cut out two 24''x 24'' squares at opposite corners in the basement floor and dig out the dirt to the bottom of the footing.
His cost is $500.00 and includes a report.
Old 10-16-2012, 06:13 PM   #20
AHH, SPANS!!!
Rewards Points: 1,166
That is great! I've dug many examine it holes before the work begins, never know what you will find...
hand drive is offline   Reply With Quote
Old 10-16-2012, 06:31 PM   #21
123pugsy's Avatar
I got started tonight.
No point worrying about how to cut back floor joists if I have to end up using real wood siding.
Old 10-19-2012, 04:30 PM   #22
123pugsy's Avatar
Originally Posted by hand drive View Post
That is the best idea, have someone local looking at the detailed plans and foundation structural detail. Is the brick adding a lot more considerable weight to the structure?
Thanks for this comment. It got me thinking about the extra weight.
I figured it would hold but I'm certain now after the testing.
200 kpa which comes out to 4000 PSF. The chart I found on line for a 2 story wood framed, 4" brick veneered house calls for a minimum 10'' wide footing. Another source calls for 12" minimum. I've got alot to spare so no worries.
http://www.concretenetwork.com/concr...dimensions.htm
http://www.ci.bloomington.mn.us/hand...foundation.pdf
Need help making a 'back band' around window/door casing. RickDel Carpentry 3 07-15-2010 03:13 PM
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
Bathroom Alcove Larger than Tub--Old Home--How to build ledge behind tub? IndyRyan Building & Construction 4 02-02-2010 11:24 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 08:05 PM
Severe Drainage Issue kirridam Landscaping & Lawn Care 11 07-25-2009 06:44 AM
