Cutting Asbestos Siding - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-21-2008, 11:55 AM   #16
Originally Posted by Maintenance 6 View Post
Some guys just have a real tough time finding a mask that fits. I have tried a bunch of different ones. Wilson's seem to work better than MSAs. 3Ms don't work at all for me. That's why I say, you have to try a bunch of types and sizes sometimes. If N100s work, then go with them. They have the same protection rating or better and you don't have to clean them. Just toss 'em.
I wear mine most of the time when I am working in anything dusty especially with sanding sheetrock, working with insulation and working in closed spaces with my sawzall.
You can toss out a used mask but it's hard to toss out a used lung.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-21-2008, 03:44 PM   #17
Having worked in the electrical trade, I've seen quite a bit of asbestos in my life. For some reason I've not experienced the dire consequences that have befell most of my work mates. Most have met an early demise from lung disease.
Its my opinion that asbestos dust must be minimized to the greatest extent!
No way should it be sawn or ground!
Even if its well wetted the dust will be carried to the ground and then when it dries, it will be blown all about, and contaminate the whole area.
The most cost efficient way would be to carefully remove all the shingles, as carefully as possible and have them buried in a land fill.
Then, reside with something like aluminum or vinyl.
Old 12-03-2008, 11:02 PM   #18
I have respect for asbestos but keep in mind that it is a natural occurring mineral.
When I was young and lived in Minnesota we used to walk over it all the time. We kicked up a lot of dust on it as did most of the hikers in the Boundry Waters Canoe Area where it is very common.
Being that the government is intent on our total protection I am surprised that they haven't closed down northern Minnesota.
Old 12-04-2008, 06:53 PM   #19
Or at least give it over to Canada. We could swap Quebec for MN.
Old 12-04-2008, 07:35 PM   #20
What! And have to speak French?
Old 12-04-2008, 11:03 PM   #21
Doncha wanna parle vous le ding dong!
Old 12-06-2008, 05:42 PM   #22
Cool
Transite siding is usually 12" x 36" is there a hardiboard similar in size or finish that you could substitute? Are there any scrap transite pieces that you could cut in a controled environment with a clear plastic bag over a wet piece of transite?
losttool is offline   Reply With Quote
Old 12-06-2008, 06:00 PM   #23
I have looked all over for something that would be a good replacement. Can't find anything.
They are going to tear down the house across the street and they have the same siding. But it won't be coming down till next year some time so I figured that I would just cut it, seal is up and call it good.
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
Is this Asbestos Siding or Cement Siding? Pictures inside!!!! twilightcall Remodeling 12 02-01-2008 08:27 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
