Cutting Architectural Shingles To Create Stair Step - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 12:37 PM   #1
cutting architectural shingles to create stair step
I'm wondering:
I've always heard you're supposed to cut off 6" per row of shingles to create the staggered joints. So the first one you'd cut 6", second 12", third 18", and so on.
But, with standard 39" long architectural shingles, wouldn't it make more sense to cut them at 7 13/16" so they are evenly divisible? In other words, each piece you cut off can be used again higher up the roof, whereas the 6" method creates a piece of waste eventually.
What's the standard procedure here?
I've done two roofs so far with the 6" method and never thought twice about it.
Thanks.
wombosi is offline   Reply With Quote
Old 10-13-2011, 01:01 AM   #2
firehawkmph's Avatar
Rewards Points: 1,800
Follow the manufacturers instructions for the metric shingles. They are not always cut evenly. If the instructions aren't on the wrappers, go to their website. The unequal cuts are tied to the patterns of the shingles.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 10-13-2011, 07:19 AM   #3
What he said, following the manufacturers directions. But we always do it as you described, which is usually the manufacturers recommendedation. The purpose of this is it makes all verticle joints at least 6 shingles from the last verticle joint.
Old 10-13-2011, 09:27 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 820
Not too many people can tell the difference between 7 13/16" or 6" from 20' away.....
I think when I did mine, I went 12", 24"......less cutting.....
But I have found an easier way.....Edurardo.....licensed....and he does great work.....lets me watch the rook go on while I drink a beer or two...or three.
Architectural shingles to buy vs. regular vkerns Roofing/Siding 24 08-04-2016 05:31 PM
how to make ridge cap shingles with tabless architectural shingles kw151002 Roofing/Siding 3 07-10-2009 08:15 AM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 07:50 AM
reg. or Architectural shingles? fricandfrac Building & Construction 6 04-02-2009 05:47 PM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
