Cutting Aluminum Soffit - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 11:08 AM   #1
RAS
I plan to install couple of spot lights behind the soffit and cut holes just for the light to protrude out and point at the house number.
I have no trim cover to hide any inaccurate cut.
What is the best way to cut the hole?
Thanks much in advance for the answer.
RAS is offline   Reply With Quote
Old 06-14-2011, 12:18 PM   #2
DIY staff
Rewards Points: 7,174
A nibbler----Kind of like a paper punch with power---tin snips work but might distort the thin metal.
A center cutting snip will also do--it has two fixed anvils with a cutter in between. It removes a 1/8" wide ribbon of metal.
Old 06-14-2011, 12:32 PM   #3
Rewards Points: 104
Not sure exactly what you have in mind, although I have a general idea, but you'll want something to keep squirrels, bats, wasps, etc. out of there.
Old 06-14-2011, 02:18 PM   #4
Next Time...New Build
Rewards Points: 150
A hole saw in reverse could also do it.
RickyBobby is offline   Reply With Quote
aluminum soffit repair question bergerdude Building & Construction 9 03-26-2011 03:01 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Soffit Venting for Aluminum Sofits kevn83 Roofing/Siding 3 07-23-2008 08:05 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
