Cutting 2 Adjacent Studs In Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 10:30 PM   #1
Question
cutting 2 adjacent studs in load bearing wall
I need to cut 2 adjacent studs in my barn. This is a unfinished interior 24x32 structure. My plans are to cut the studs out and frame it like a window. The locker is 36" x 72' metal. I intend to install the locker in the opening and secured in place by using lagscrews thru the side of the lockers into the 2x4s installed to support the header installed above the lockers. Please excuse any improper nomenclature as I am new to this carpentry.
ANY help or tips will be greatly appreciated.
Chuck
txbiker is offline   Reply With Quote
Old 02-18-2013, 10:50 PM   #2
Registered User
Rewards Points: 4,894
If the wall is not a required special "shear wall panel", you may be alright to go. Use the proper sized header for the span/loads (keep in mind these are for residential, prescriptive codes), check with local AHJ; http://publicecodes.cyberregs.com/ic...002_par021.htm
May want to add some foamboard or the metal back may condense moisture to rust (if ever condition the inside)...
Gary
PS. welcome to the forums!
The Following User Says Thank You to Gary in WA For This Useful Post:
txbiker (02-18-2013)
Tags
loadbearing wall , stud
Moving wall studs in load bearing wall thardyjackson Carpentry 10 02-11-2013 03:10 PM
Load bearing wall? renntecher Building & Construction 2 02-04-2013 02:35 AM
Cutting opening in Load Bearing wall mae-ling How To Guides 2 02-18-2012 11:02 AM
creating door in possible load bearing wall acerunner Building & Construction 6 07-05-2010 05:33 PM
Moving studs on load bearing wall for HVAC? grouse Building & Construction 1 08-20-2009 03:16 PM
