Cut Through 50% Of Floor Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-26-2011, 03:54 PM   #1
Cut through 50% of Floor Joist
While removing a sofit in my kitchen, I accidentally cut through the bottom half of the ceiling joist. What should I use to re-brace this?
Cut through 50% of Floor Joist-p1010499-large-.jpg   Cut through 50% of Floor Joist-p1010500-large-.jpg
badgerland is offline   Reply With Quote
Old 09-26-2011, 04:05 PM   #2
Rewards Points: 150
The accepted practice around here would be to block along side of it, 24" to either side of the cut with the same size material. So you'd basically would nail and glue a 2x xx at least 4 ft long and center it on the cut. My preferred way, if the builder has the materials, is to sister the thing from one end to the other. Sometimes that won't work because of plumbing or electrical so we make the sister piece as long as possible and center it on the cut. Never had an issue with either fix.
TrapperL is offline   Reply With Quote
Old 09-26-2011, 06:04 PM   #3
Framing Contractor
Rewards Points: 118
How do you "accidentally" cut that far into it? Sister that with a full joist if at all possible.
sixeightten is offline   Reply With Quote
Old 09-26-2011, 06:37 PM   #4
kwikfishron's Avatar
Rewards Points: 586
No more Sawzall after Red Bull for you.
Welcome to the forum badgerland.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
VIPlumber (09-28-2011)
Old 09-27-2011, 10:59 AM   #5
Should the new block be nailed or screwed, is one better than the other?
Anything special to glue them together or simple PL Premium?
Thanks for the help!
Old 09-27-2011, 04:42 PM   #6
Rewards Points: 590
Good thing it wasn't the next joist over, or you would have been able to find out whether your blade was suitable for BX!
operagost is offline   Reply With Quote
Old 09-27-2011, 05:24 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,202
pl premium or lumberlock will do fine, sistering the full length of the joist is the best thing to do but if you cant get it in do to pipes and electrical either call someone to reroute the lines or just do as others have stated and install the longest peice of lumber possible
woodworkbykirk is online now   Reply With Quote
Old 09-28-2011, 07:36 PM   #8
Rewards Points: 1,088
You could either sister with another 2x8 or you could buy some steel brackets or plates and bolt them on by sandwiching joist. Make sure you apply constructive adhesive everywhere including inside the cut.
handy man88 is offline   Reply With Quote
Old 09-28-2011, 07:43 PM   #9
Rewards Points: 150
Yuuuuuuup!
OhioHomeDoctor is offline   Reply With Quote
