Cut Nails Not Holding Strong In Concrete - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-20-2010, 06:00 PM   #16
Concrete & Masonry
Rewards Points: 620
Originally Posted by Mr Chips View Post
there are no license requirements for a contractor or DIY'er to buy loads. i'm not sure, but would be willing to bet you can buy red loads at your local depot or lowes
Last I saw was the "green" loads there, but it's been a long time since I used the powder gun.
I bought one of these instead:
http://www.powers.com/product_55011.html
jomama45 is offline   Reply With Quote
Old 08-24-2010, 03:59 PM   #17
So they actually have these ramsets at the local box store in tool section. (Never even noticed em before) The guy at the rental section though said they probably will only chip up my floor and not hold well. Said most guys who rent them just bring em right back after trying to use on an old concrete floor. I may still try it though just for the h of it. I have to do furring strips into block too so it should at least work or that.
Originally Posted by GBR in WA View Post
That old of a house, I doubt there is any vapor barrier plastic under the slab. If this space will be heated, I suggest adding some sill sealer between the p.t./slab for a thermal and capillary break.
Thanks for this advice on the vapor barrier. I actually wasnt even going to use p.t. for the bottom plates but I guess I should. We never did that back in the day when I was a helper building houses.
And I hadnt even thought of this but should the drywall that touches the ground be greenboard? (I am plannin on doin a decorative concrete overlay on the floor.)
And you guys were right about the sledge, it sure aint 30 lbs. My bro gave it to me for xmas and told me it was 30 lbs. and i never thought twice about it. Shows how dang weak Im gettn these days that I didnt even notice!
lateralus is offline   Reply With Quote
Old 08-24-2010, 05:18 PM   #18
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
A sledgehammer under the christmas tree, that is PRICELESS. Did he wrap it, or just a nice big bow? I love it! It's better than most of the crap my relatives get me!!
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-25-2010, 08:42 AM   #19
Rewards Points: 4,744
keep your drywall 3/4" above the conc floor,,, dec conc o'lay's a good thought - just do your floor prep right ( muriatic pickling & neutralizing )
sledge reminds me of the time i got the ex-wife a self-propelled lawnmower for mother's day ( not cool as i later discovered )
Old 08-27-2010, 01:12 PM   #20
Nah he just wrapped up the business end with the yellow handle stickn out .
I was trying to go no base trim (the wife is not a big trim fan) so the 3/4" gap probably wont fly.
Muriatic pickeling and neutralizing
thems some big words. I was planning on hiring a contractor anyway but what does that involve exactly?
And another question on that note, if I use http://www.citrusdepot.net/info_mastic.html to remove the mastik, do think it will alter the floor chemically where it would have an effect on trying to put down an overlay?
Old 08-27-2010, 06:48 PM   #21
placing the dry wall right on the floor's a no-no as it could suck up ( capillary action ) moisture leading to mold/mildew,,, baseboard's more attractive in our house
pickling's a prep step to promote adhesion of dec conc overlays,,, if acid staining, just prep w/swing buffer, black pad, & tsp then rinse a couple times,,, citrus i don't know as we prep mechanically ( grinders/scarifiers ),,, if you're hiring a pro, he should know what to do,,, many times tile ghost lines can always be expected even thru an o'lay which's why we use 3 coats.
Old 08-27-2010, 08:06 PM   #22
Tom Struble's Avatar
Rewards Points: 2,002
these are my favorite conc anchor
Tom Struble is offline   Reply With Quote
Old 08-27-2010, 09:21 PM   #23
kwikfishron's Avatar
Rewards Points: 806
That's to simple.
kwikfishron is online now   Reply With Quote
Old 08-28-2010, 04:36 PM   #24
thats why its good for me
Old 01-04-2011, 03:44 PM   #25
following up
So just to follow up...I bucked all of the recommendations!
(no offense ) I ended up borrowing one of these from a friend. Wonderful tool I didn't even realize was out there.
Old 01-04-2011, 04:06 PM   #26
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Cheater! A little easier than banging cut nails, no doubt.
So, you got a sledgehammer for christmas last year.... what did your brother get you this year, crow bar?
Old 01-04-2011, 07:16 PM   #27
Rewards Points: 1,666
I bought one of these and it worked fine for the only time I'll ever use one:
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Best deal for the money spent. No sledge hammer swinging. Wear ear and eye protection!
bob22 is online now   Reply With Quote
Old 01-04-2011, 08:06 PM   #28
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
PAT is good for certain things and will take the place of cut nails for sure, but remember: it's a fastener, not an anchor. make sure you are aware of it's limited holding power!
Old 01-07-2011, 04:05 PM   #29
Ha, no cd this year.
Old 01-07-2011, 05:24 PM   #30
Ramset/hilti gun as suggested. You're not holding the plate down, you're holding it from going side to side.
mrgins is offline   Reply With Quote
Crumbling Front Porch - Part 2 - The Repair jerseyguy1996 General DIY Discussions 9 04-11-2010 06:11 AM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Filling sunken living room w/ concrete Q's phil. Building & Construction 5 07-10-2009 12:03 PM
Adding a ceiling!? My whole house is concrete! flipjarg Remodeling 9 12-02-2008 12:20 PM
Laid Down Concrete Incorrectly overzealous Building & Construction 6 06-03-2008 06:44 PM
