Cut Hole In Load Bearing Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 01:39 AM   #1
Question
Cut hole in load bearing block wall
I have a load bearing cmu block wall (roof ties into it) that a plumber had to access inside to get to a water line to abandon. To do this he knocked out approximately a 12" tall by 8" wide hole in the wall near the bottom with a hammer (wall is a 10' tall and 8x4x16 open cell block not filled or rebar). See image.
Should I be concerned about the structural integrity of the wall being compromised from a hole this size, or should I add any kind of support to it?
Also, what can be done to cover back up the hole?
phxmod is offline   Reply With Quote
Old 08-08-2013, 10:37 PM   #2
Msradell's Avatar
Rewards Points: 120
If the loading is just that of a normal roof you should not have any concerns about the integrity of the wall. The rest of the structure of the wall is interlocked sufficiently to overcome this matter hole. How you cover up the hole depends on the use of the area. You could just simply attach a sheet of plywood with anchors to cover it if appearance doesn't matter. If you want to look like the rest of the wall you could buy a couple of blocks, remove the faces and mortar them into place.
Msradell is offline   Reply With Quote
concrete block step crack - load bearing wall cbrett1979 Concrete, Stone & Masonry 3 03-10-2012 11:07 PM
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 07:17 PM
Door opening in load bearing block wall SS396 Building & Construction 12 09-13-2010 06:27 PM
Modifying a Load Bearing Wall acme54321 Building & Construction 1 08-21-2010 12:29 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
