Old 02-28-2013, 12:37 PM   #1
cut brick wall
What tools can I use to cut a brick wall
DIYQUEN is offline   Reply With Quote
Old 02-28-2013, 01:05 PM   #2
cut brick wall
A brick wall cutter.
hammerlane is offline   Reply With Quote
Old 02-28-2013, 01:15 PM   #3
Haverhill Trade 1965
cut brick wall
Depends how much you are cutting, and what you are doing. You can get a diamond grit 7" circular saw blade for under $50 but it only cuts about 2 1/4" deep. There are some you can rent at tool rental places that are larger. You can use a hammer and brick chisel if you are only taking out a few bricks.
Duckweather is offline   Reply With Quote
Old 02-28-2013, 02:21 PM   #4
cut brick wall
If its a solid wall, use a hammer and chisel.
If its a veneer, safer to use a disc cutter.
tony.g is offline   Reply With Quote
Old 02-28-2013, 04:25 PM   #5
cut brick wall
Need more info and some pictures.
There's company's that all they do is cut concrete. There going to have the tools and know how to make a perfect cut and will know how to cut in to add a steel support once it's been cut.
Once it's cut out every other 1/2 block will need to be cut out and replaced with a 1/2 block to end up with a smooth surface.
My garage wall bricks seems to be cracking where the brick wall contacts Unicornz0 Concrete, Stone & Masonry 2 09-05-2012 10:31 PM
How to face a cinder block retaining wall with stone? CarrollY Concrete, Stone & Masonry 5 09-04-2012 01:26 PM
Concrete Plaster coat Mix ratio needed, for brick interior wall. Spud Concrete, Stone & Masonry 6 07-08-2012 02:55 PM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
