Custom Curved Window - Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 11:49 AM   #1
Rewards Points: 502
On the back of our house, there is a large curved "bay" window with 18 separate frames of glass.
These are the only remaining single pane windows in the house, which makes this room cold in the winter.
I had thought about replacing each pass with a double-pane, but I don't think the existing wood frames would support that much additional weight.
I am willing to think outside of the box of tearing out all the wood framing and putting 6 tall pieces of glass in.
Thoughts and Suggestions?
Custom Curved Window - Replacement-curved.jpg   Custom Curved Window - Replacement-curved2.jpg
-Andrew
DIY hobbiest
AndrewF is offline   Reply With Quote
Old 01-12-2009, 09:08 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
Looks like your projection on the existing unit is a little too much.Its hard to tell from the pic but it looks to be even with the outside of the gutter that makes it difficult to close in properly
I Would recommend a replacement bay unit with less projection or you could put a combination of venting and non venting casement units in each vertical section
Tom Struble is offline   Reply With Quote
Old 01-12-2009, 09:23 PM   #3
Rewards Points: 502
I'll get some better photos. Yes, top is even with end of sofit.
Bottom has built out brick unit.
-Andrew
DIY hobbiest
Old 01-12-2009, 10:32 PM   #4
Andersen and Marvin both could make a custom bay window- looks like 10 degree bow- but definte stay under soffit if at all possible. Pretty any MFG could make it -if it doesn't need to vent- good luck- call a Local Contractor Yard Outside salesman- and ask him to come out and measure with a MFG rep
EMILY P is offline   Reply With Quote
(true) Replacement window cost windowpoor Remodeling 20 10-05-2011 10:20 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 05:17 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
latest problem...window replacement gone_fishing Remodeling 10 02-11-2008 08:24 AM
