Custom-build Utility Tub On Concrete Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 01:04 PM   #1
Rewards Points: 1,062
Question
custom-build utility tub on concrete floor
this thing is going to be something like a floor tub in a janitorial station, i.e sitting on a concrete floor and will be finished with tile.
but i was wondering whether water will be making its way through the grout and soaking the concrete and whether that will eventually cause breakage ?
i know that when building tiled custom showers on wooden platforms, there is a PVC liner that is placed below (?) the cement board to stop leakage. but i do not know how i would incorporate something like that straight on concrete ?
thanks,
- a -
Old 06-16-2008, 02:01 PM   #2
RippySkippy's Avatar
I would make the basin out of what ever you wanted 2x and plywood, then build the liner from Kerdi and tile as normal. Make a mud bed for the floor sloped like a shower, kerdi the bottom up the sides over the top and down the front, onto the existing cement floor.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-16-2008, 02:19 PM   #3
are you saying put the liner over concrete, then mud bed, then tile over ?
confused (but thankful).
- a -
Old 06-16-2008, 03:02 PM   #4
No; mud bed, kerdi, tile.
LMASD
Old 06-16-2008, 03:06 PM   #5
Question
is kerdi the PVC liner ?
how do you make a mud bed ? what is it made of ?
Old 06-17-2008, 07:36 AM   #6
Here's a great resource for the mud and kerdi is not like any PVC liner you'll ever use. The pros will argue it's better since it creates a water proof barrier between the tile thin-set and the substrate. Here's a brochure about the product, and a detailed drawing of the installation. Google for online sources, some local places may carry it, but I've had better luck on line.
LMASD
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
cold concrete floor RuthP Flooring 4 02-03-2008 10:13 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 09:52 PM
Concrete deck -- rotting floor joists jwill Building & Construction 6 09-05-2007 08:01 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 01:32 PM
