-   -   custom-build utility tub on concrete floor (http://www.diychatroom.com/f19/custom-build-utility-tub-concrete-floor-22341/)
amakarevic 06-16-2008 01:04 PM
this thing is going to be something like a floor tub in a janitorial station, i.e sitting on a concrete floor and will be finished with tile.
but i was wondering whether water will be making its way through the grout and soaking the concrete and whether that will eventually cause breakage ?
i know that when building tiled custom showers on wooden platforms, there is a PVC liner that is placed below (?) the cement board to stop leakage. but i do not know how i would incorporate something like that straight on concrete ?
thanks,
- a -
RippySkippy 06-16-2008 02:01 PM
I would make the basin out of what ever you wanted 2x and plywood, then build the liner from Kerdi and tile as normal. Make a mud bed for the floor sloped like a shower, kerdi the bottom up the sides over the top and down the front, onto the existing cement floor.
amakarevic 06-16-2008 02:19 PM
are you saying put the liner over concrete, then mud bed, then tile over ?
confused (but thankful).
- a -
RippySkippy 06-16-2008 03:02 PM
No; mud bed, kerdi, tile.
amakarevic 06-16-2008 03:06 PM
is kerdi the PVC liner ?
how do you make a mud bed ? what is it made of ?
RippySkippy 06-17-2008 07:36 AM
Here's a great resource for the mud and kerdi is not like any PVC liner you'll ever use. The pros will argue it's better since it creates a water proof barrier between the tile thin-set and the substrate. Here's a brochure about the product, and a detailed drawing of the installation. Google for online sources, some local places may carry it, but I've had better luck on line.
