Curved Form For Concrete Footing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-08-2011, 09:17 AM   #1
Rewards Points: 121
Curved form for concrete footing
I am attempting to create a curved form for a concrete footing. I am not having much luck. I cut a series of kerfs on the back of the wood that will be used for the forms, but when I try to bend the wood it sometimes breaks at the kerfs. I need some tips on how deep to make the kerfs and how far apart they should be, and also what type / size (thickness) wood to use. The footing will be used to support standard CMU's, the radius is approx 20', the length is approx 25'.
jrepp44 is offline   Reply With Quote
Old 12-08-2011, 09:20 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You don't kerf wood, you use a piece of primed fiberboard siding. It will bend almost as tight as you would need in most cases. If the radius is really tight use multiple layers of 1/8" panelling or 1/4" plywood.
Old 12-08-2011, 09:21 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,... We use luan, or sheet steel, with extra pinnin'....
The Following User Says Thank You to Bondo For This Useful Post:
Bud Cline (12-08-2011)
Old 12-08-2011, 05:51 PM   #4
Concrete & Masonry
Rewards Points: 568
For a 20' radius, a 1x8 should bend just fine, it's not that tight. If you think it's going to break, get them wet for a few hours before hand.
Primed 1/2" masonite siding works well also, but I wouldn't personally use it unless the radius was under 10'.
jomama45 is offline   Reply With Quote
Water supply line runs through footing site WillK Building & Construction 19 03-15-2011 01:39 PM
What is the on the base of the footing for standard circular steel form work for concrete be 12" wall and 36' foundation undation? william lum Building & Construction 1 06-24-2010 06:45 PM
Footing drains in crawlspace on top of footing jbitt Building & Construction 8 01-12-2010 01:50 PM
Sinking footing tubes Farmer Z Building & Construction 19 11-17-2009 08:50 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
