Curing Period For Stucco??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 01:31 PM   #1
curing period for stucco???
I want to know what is the curing period for 3 coats system stucco between coats.Our contractor wants to apply the brown coat after 3 days of puting the scratch coat. Is this right?
Thank you,
michelleb is offline   Reply With Quote
Old 09-23-2010, 02:46 PM   #2
concretemasonry's Avatar
Rewards Points: 2,626
Three days would be more than enough. Many people prefer less since a newer scratch coat may provide a better surface.
Dick
concretemasonry is online now   Reply With Quote
Old 09-24-2010, 10:12 AM   #3
Rewards Points: 1,232
Under the proper conditions and with proper technique, the brown coat can be apllied the same or the next day. As a rule, the sooner the better.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 09-25-2010, 06:33 AM   #4
Rewards Points: 4,726
get it done,,, IF the base courses are TOO dry, adhesion's eventually a problem,,, who hired this contractor - YOU or the builder ? don't take the tools out of his hands unless you KNOW ( message boards do NOT count ! ) work's not being done properly,,, we walk off jobs when that happens
updated pics of stamped concrete curing amandalc04 Building & Construction 20 06-01-2010 09:50 PM
curing concrete slab Jeremy Hillary Boob, PhD Building & Construction 14 12-10-2009 12:17 PM
Concrete curing in post holes moneymgmt Building & Construction 5 11-19-2008 10:01 AM
Curing concrete? grumpybear Building & Construction 33 07-15-2008 11:49 PM
24 hours curing time enought? KUIPORNG Flooring 4 02-28-2007 08:23 AM
