Cultured Stone Mortar Type? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-30-2009, 06:49 PM   #1
Rewards Points: 256
cultured stone mortar type?
Installing interior cultured stone - first time using product or installing any other kind of masonry. Question about mortar. I read that I need a Type "N", but I only found separate ingredients (portland cement and sand) at Lowe's. I was looking for a "pre-blended" mix. Found pre-blended Type S at Home Depot. They look like they are for the same uses. Can I use Type S for cultured stone install? Thanks in advance.
tpagel is offline   Reply With Quote
Old 06-30-2009, 08:25 PM   #2
Remodeling Contractor
yes. or use thinset which will stick better and make your job easier.
Old 07-01-2009, 12:04 AM   #3
Concrete & Masonry
Rewards Points: 470
If your going for grey grout joints, I would recomend the Type S premix. Less confusion & you can use it for the entire job. Don't be misled by the "Quikcrete" label, it really is a good product, especially for what you are intending to do with it.
jomama45 is offline   Reply With Quote
Old 07-01-2009, 08:35 AM   #4
Rewards Points: 256
Can Type N not be used for the entire job? If I got Type N, would I still need to use Type S someplace? Cultured Stone installation guide only mentions Type N I think
Old 07-01-2009, 12:00 PM   #5
Type N will be fine
Old 07-01-2009, 04:57 PM   #6
Rewards Points: 95
For an interior application I would recommend using thin-set as Bob mentioned, to adhere the stones with. If you are using a stone with joints I would then use the quik-crete bags of mason mix (type S) to point the joints in.
NJ Brickie is offline   Reply With Quote
Old 07-01-2009, 05:26 PM   #7
I guess this depends on the weight of your stones. Type N is fine. Type S offers a stronger cement and should be used for heavier stones. Thinset allows better adhesion but is better used indoors.
Old 07-01-2009, 06:57 PM   #8
Rewards Points: 95
Weight is not really the issue here. With cultured stone adhesion is the main quality you need. As you said the thinset will give you good adhesion thats why I use it on interior applications.
Stone wall problem with mortar weberus3 Building & Construction 22 01-06-2010 09:06 AM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 11:56 PM
Fixing mortar joints on cultured stone ??? WoodyII Building & Construction 2 05-16-2009 01:48 PM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 08:44 PM
