Old 05-21-2010, 10:26 PM   #1
Question
Cultured Stone
To lay 250 square feet of cultured stone the supply companies rep is telling me I need 25, 80 lb bags of mortar, seems a bit much, and another guy at a home box store said 8 to ten bags would be enough. That's quite a big difference. My question is who is right, if any?
Hardstone is offline   Reply With Quote
Old 05-22-2010, 09:05 AM   #2
Concrete & Masonry
Cultured Stone
If you mean 80# premix bags, I suspect that the manufacturer is a little closer in their estimation. The pre-mix bags yeilld little more than a 5 gal. pail when mixed. I assume you need to plaster the lath on the wall as well, which will use a good amount of mortar.
Without knowing all the details, or how well you handle a trowel, I'd guess around 20 - 80#'s if you're using pre-mix.
jomama45 is offline   Reply With Quote
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 1 11-09-2009 05:29 AM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 11:56 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
