Cultured Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 11:54 AM   #1
cultured stone
I will be laminating a brick fireplace with Boulder Creek Ledgestone (cultured stone). Can I use thinset? What type and size trowel?
Harry1 is offline   Reply With Quote
Old 05-18-2010, 01:01 PM   #2
Rewards Points: 156
Harry,
I recently refaced my fireplace with a similar product. I suggest you do the following.
Hang wire mesh over the area that the stone is going to be applied to. Apply a 'scratch coat' over the entire area using type N mortar (basically just a thin coat of mortar over the entire area). Let that dry for a day or two, the wire mesh will get hard as a rock. Then use the same mortar to hang your cultured stone. You want a pretty wet mixture of mortar I found out.
Branden is offline   Reply With Quote
The Following User Says Thank You to Branden For This Useful Post:
Harry1 (05-18-2010)
Old 05-18-2010, 04:37 PM   #3
I agree with branden for the most part however some suppliers actually tell you to adhere the vaneer using a strong epoxy based tile glue. If is fast setting and easy to work with. If you are using ledgestone then you most likely want a dry stack look.
ArchTech is offline   Reply With Quote
The Following User Says Thank You to ArchTech For This Useful Post:
Harry1 (05-18-2010)
Old 05-18-2010, 07:25 PM   #4
Rewards Points: 5,336
You would follow the manufacturer's directions concerning this installation. If the cartons did not contain the directions, contact them directly.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Harry1 (05-18-2010)
Old 05-18-2010, 07:29 PM   #5
Ron
The older I get the better I was
What to do where cultured stone veneer meets grass shleppy Landscaping & Lawn Care 5 09-03-2014 07:39 PM
J-Weep / Flashing for exterior cultured stone veneer wall. Spud Building & Construction 18 08-31-2009 10:44 PM
Cultured stone issues jdrolls Building & Construction 1 06-14-2009 11:56 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 06:38 AM
