Cultured Stone? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2006, 06:15 PM   #16
Rewards Points: 552
Originally Posted by Tscarborough View Post
No it isn't. Stucco is a perfectly viable and attractive option. And when I say stucco, I mean three coat cementious stucco, not synthetic.
Okay, so given your expertise, what solution do you feel would look the best and most authentic for my situation? And no, I can't afford real stone.
kcrossley2 is offline   Reply With Quote
Old 12-17-2006, 06:20 PM   #17
Rewards Points: 1,220
Given the front elevation, if it were me, I would stucco the entire house as I could afford it, and would possibly use faux rock on the garage, provided the foundation was not exposed. If stucco was not an option, then I would just plan on using faux rock to dirt, though I would probably have different stones with a watertable between at the foundation line.
edit-I give opinions on style, not expertise.
Tscarborough is offline   Reply With Quote
Old 12-17-2006, 06:35 PM   #18
Rewards Points: 552
What's a watertable?
Old 12-17-2006, 06:41 PM   #19
Here is a detail of a Cultured Stone watertable:
http://www.culturedstone.com/technic..._tr_wtrtbl.pdf
The purpose is to allow for a change in the thickness of the wall, and also as a way to waterproof said change.
Cultured stone? kcrossley2 Building & Construction 11 03-30-2008 03:33 PM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
Help! What is Proper Way to Install Manufactured Stone? EricW Building & Construction 3 01-07-2007 04:56 PM
HELP! Question about Eldorado Stone EricW Building & Construction 8 10-24-2006 05:24 PM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 08:44 PM
