Cultured Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-25-2009, 03:24 PM   #1
Question
Cultured Stone
I have purchased a standard California stucco house in the Palm Springs area and would like to customize my landscaping. My plan is to put cultured stone on the exterior of my fireplace to match the stone on the exterior of the spa.
Do I need to do something to the fireplace exterior or can I just use thin set to glue the cultured stone to the current sprayed on plaster on the fireplace?
GGGreen is offline   Reply With Quote
Old 04-25-2009, 04:06 PM   #2
Remodeling Contractor
It will depend on the weight and type of stone used. Since the wall is already stucco'ed you should already have a drain plain and vapor barriers that are needed. But the type of adhesive may be determined by the stone used. Check recommendations from the supplier.
Tags
stone instalation
cleaning cultured stone?? samiam Interior Decorating 3 09-27-2008 08:59 PM
Cultured stone around fireplace MichaelP Building & Construction 10 06-21-2008 05:38 AM
Repair of a piece of cultured stone that fell off apprentice General DIY Discussions 2 11-26-2007 01:27 PM
cultured stone mortar mix? ducter Building & Construction 1 09-18-2006 07:44 PM
