Cubby Above A Closet - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2011, 04:30 PM   #1
Cubby above a closet
Hi everyone,
I don't know how to finish off a cubby above a closet.
I'll explain where it is, I have a split entry home and when you walk in my front door there is a closet to the right, well on the other side of that wall is a bedroom and above the closet that is in the front porch there is a cubby in the bedroom that goes to the ceiling. so there is esantially a half wall and then a opening that is 32" deap and 74" wide a to the ceiling
I have a tv connection and recepticle there for a tv because it will eventually be a kids room.
I have a couple ideas to finish the platform or bottom of the cubby and wanted to run this by everyone and take suggestions as well.
1) Sheet of mdf painted white and trimed with 3" baseboard from the mdf to the wall or possibly painted the same color as the walls so it wouldn't just be this big white platform
2) pine boards glued together and urethaned and trimed the same as above.
3) Drywall and use round outside corner to have the wall underneath the platform blend into the platform and paint it all the same color as the room.
any ideas will be greatly appreciated i can post a picture as well if it will make it easier for people to picture what i'm talking about.
nlmedic is offline   Reply With Quote
Old 09-19-2011, 08:28 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Yeah, I think pictures would definitely help.
Old 09-20-2011, 06:06 AM   #3
Here are some pics I think this will help
Old 09-20-2011, 09:37 AM   #4
Stuck in the 70's
I would go with MDF. Getting pine boards secured flat and even would be difficult, and drywall would get damaged too easily.
Old 09-20-2011, 10:29 AM   #5
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
How about putting a nice countertop in there. It would be very sturdy and durable for your future TV and "future" kids.
Oh-Fudge is offline   Reply With Quote
Old 09-20-2011, 10:30 AM   #6
That's the direction I was going as well. I was also going to have it overhang the edge an inch or two and put a small piece of crown under it like an apron for a window.
Do you think I should paint it the same color as the walls and have the trim white or paint it all white? I didnt know if it would look odd if it was white. It could have a cushion up there for a kids bed or play spot or even just a spot for books or Teddy bears or what not.
Old 09-20-2011, 10:35 AM   #7
Hey the counter top idea is interesting as well. I could still trim around the walls with 3" baseboard and the counter top would cover the edge as well.
Framing a new header for closet opening jmai14 Carpentry 6 07-09-2011 02:20 PM
Laundry closet decision LClark Remodeling 2 06-26-2011 06:19 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Hardwood closet threshold question DIY-Renovator Flooring 1 07-27-2008 04:42 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 08:36 PM
