Crumbling Plaster On Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-07-2005, 08:05 AM   #1
Unhappy
Crumbling plaster on walls
The paint and thin layer of plaster beneath is crumbling. Someone suggested it might be salt working through from the brick underneath. What can I do?
gusfagan is offline   Reply With Quote
Old 08-13-2005, 10:07 AM   #2
Hi, you have , or your wall has, efflourescence (might not be spelt right) which is indeed the lime salts being liberated from either the bricks or sometimes the plater. The standard cure is to expose it, brush it off with a wire brush, seal the brickwork and replaster the area. It can be caused by damp penetration, or sometimes just happens !!! Good luck
christofish is offline   Reply With Quote
Old 08-13-2005, 10:59 AM   #3
Thanks. Forgive one more silly question - seal the brickwork with what?
