Old 07-04-2010, 11:46 PM   #1
crumbling field stone sandstone foundation...can we resurface the visible outside portion?
We have a 90 yr. old home. There is about three feet of exposed above ground foundation with painted field stone sandstone foundation that is peeling and crumbling in many places. There are also some places that have a crystal like appearance on top of the bubbling painted surface. Because of the condition and the style of this exposed foundation, we would like to resurface it so it looks more aesthetic. The field stone has a shallow crater like apperance. Is there an inexpensive DIY solution that will fix our problems and if so, what products will we need? Thank you in advance for your suggestions.
btolt162 is offline   Reply With Quote
Old 07-05-2010, 07:09 AM   #2
trying to think of a nice way to say this,,,,,,,,,,,,,,,, 1, reface crumbling stonework &, subsequently, not know/see the degradation til part of the house falls down; 2, remove/replace as rqd now; or 3, do nothing ? that's the choices.
for the other part ( inexpensive ), no, not if its done right.
1st hire a structural pe; 2nd, find an OLD-TIME mason; 3rd, get rid of cable tv & use the $$$ for the repairs.
DIY ? can't suggest w/your apparent level of expertise,,, good luck !
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 07-06-2010, 01:04 AM   #3
Contractor
Brickie's Avatar
Going by what you posted, No. You have a major foundation problems. You need to call in the pros to get estimates for the repairs
Northwest Indiana Masonry
Brickie is offline   Reply With Quote
Stone Foundation Woes dandelauro Building & Construction 6 09-25-2009 04:41 PM
Pointing a stone foundation bilbobroberts Building & Construction 2 07-19-2009 11:50 AM
Cutting a hole in stone foundation casualty x Building & Construction 2 01-11-2008 07:28 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
