Crown Molding On Window Seat - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-22-2011, 04:27 AM   #1
Crown molding on window seat
I'm about to put the 'seat' on our renewed window seat w/3/4" ply. I want to use a small crown molding at front edge. Any suggestions on how to figure how much lip I need for this and should I finish ply edge 1st or just attach crown molding to cover it? RJB
R J B is offline   Reply With Quote
Old 03-22-2011, 06:44 AM   #2
Set the molding against a verticle surface as it would normally be mounted. Measure from the top front edge to the verticle surface, and add a bit for roundover and overhang. Usually about 3/4-1"
The Following User Says Thank You to Just Bill For This Useful Post:
R J B (03-22-2011)
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 12:33 PM
Crown molding inside bay window Dieter Carpentry 7 10-03-2010 06:23 PM
Crown molding to arched window tas10000 Carpentry 5 09-17-2010 03:35 PM
Crown Molding Transition over narrow gap between ceiling and window top ... NallaChiruta Carpentry 4 02-11-2010 07:34 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 10:52 AM
