Old 01-07-2013, 01:23 AM   #1
Crown Molding
Hello all,
I just put up all new drywall in my living room and I was thinking about using crown molding at the ceiling.
My question is that if I am using crown molding do I still need to mud and tape the ceiling/wall joint?
bcgfdc3 is offline   Reply With Quote
Old 01-07-2013, 01:32 AM   #2
Crown Molding
Yes to seal the envelope, other wise air will leak into the attic.
But you can get away with just one coat of mud.
Old 01-07-2013, 01:35 AM   #3
Crown Molding
I appreciate the fast response and understand what you are saying but prior to hanging my drywall I added a 6 mil vapor barrier that came down about 6 inches onto the walls where I glued it to the top plates.
I will still proably add the mud and tape anyways, just curious if I had too.
Old 01-07-2013, 06:03 AM   #4
Super Moderator
Crown Molding
Yes,you do---that single layer of tape and mud is called 'fire tape' and will slow down the advance of a fire into the plastic you used as a vapor barrier.
woodworkbykirk (01-07-2013)
making own crown molding marin001 Carpentry 7 03-29-2010 12:08 AM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Need help on Crown Molding on inset Trey Ceiling pacumming Carpentry 2 01-30-2010 01:13 AM
Crown molding on with catherderal celing for LED lights My_attempt Carpentry 20 07-22-2009 11:52 AM
Paint Crown Molding Before or After Installation? gmhut Painting 24 06-03-2009 09:38 PM
