Crown Molding
Hello all,
I just put up all new drywall in my living room and I was thinking about using crown molding at the ceiling. My question is that if I am using crown molding do I still need to mud and tape the ceiling/wall joint? Thanks |
Yes to seal the envelope, other wise air will leak into the attic.
But you can get away with just one coat of mud. |
I appreciate the fast response and understand what you are saying but prior to hanging my drywall I added a 6 mil vapor barrier that came down about 6 inches onto the walls where I glued it to the top plates.
I will still proably add the mud and tape anyways, just curious if I had too. |
Yes,you do---that single layer of tape and mud is called 'fire tape' and will slow down the advance of a fire into the plastic you used as a vapor barrier.
| All times are GMT -4. The time now is 07:08 AM. |
