Crown Miters - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 11:28 AM   #1
Rewards Points: 640
Crown miters
alright trying to do corners on crown with a compund miter saw... the darn book I have says 45 and 45 degrees... that cant be right... because when I did it with a normal miter saw and had the crown at an angle against the fence it was a much smaller piece and the angle was right .... what is the correct way to do crown on a compound miter saw?
BlueBSH is offline   Reply With Quote
Old 07-25-2010, 06:42 PM   #2
Registered User
Rewards Points: 4,902
http://www.taunton.com/finehomebuild...echniques.aspx
http://www.google.com/search?q=copin...&start=40&sa=N
http://americanwoodworker.com/blogs/...n-molding.aspx
Be safe, Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
kwikfishron (07-25-2010), Tom Struble (07-25-2010)
Old 07-25-2010, 07:10 PM   #3
kwikfishron's Avatar
Rewards Points: 84
Although my technique is slightly different, Gary’s links nail the concept to “Goof Proof Crown” (I stole that term).
kwikfishron is online now   Reply With Quote
Old 07-25-2010, 07:51 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
45deg angle no bevel,upside down and backwards...simple
Tom Struble is offline   Reply With Quote
Old 07-25-2010, 08:16 PM   #5
Rewards Points: 640
That's what I did in the past but realized I had a compound miter saw (not idea how I never noticed that before......) anyways... thought it would be easier with the compound miter... but seems like its worse...
Old 07-25-2010, 08:28 PM   #6
you use the compound only when the moulding is layed flat on the miter box
Old 07-26-2010, 07:13 AM   #7
Rewards Points: 640
yes that is what I was doing with the compound miter, I only had it upright when it was a normal miter... but when it was flat it seemed like I needed angles like 31 degrees to get the same cut that I got with the normal 45 degree upright upside down cut
Old 07-26-2010, 12:21 PM   #8
Use the ole tried and true method described above. I have a compound miter saw myself and have very rarely used the second angle. Just too easy to do crown the other way.
unlvrebel is offline   Reply With Quote
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 10:40 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
