-   -   Crown miters (http://www.diychatroom.com/f19/crown-miters-77043/)
BlueBSH 07-25-2010 10:28 AM
Crown miters
alright trying to do corners on crown with a compund miter saw... the darn book I have says 45 and 45 degrees... that cant be right... because when I did it with a normal miter saw and had the crown at an angle against the fence it was a much smaller piece and the angle was right .... what is the correct way to do crown on a compound miter saw?
Gary in WA 07-25-2010 05:42 PM
http://www.taunton.com/finehomebuild...echniques.aspx
http://www.google.com/search?q=copin...&start=40&sa=N
http://americanwoodworker.com/blogs/...n-molding.aspx
Be safe, Gary
kwikfishron 07-25-2010 06:10 PM
199 Attachment(s)
Although my technique is slightly different, Gary’s links nail the concept to “Goof Proof Crown” (I stole that term).
Tom Struble 07-25-2010 06:51 PM
45deg angle no bevel,upside down and backwards...simple:wink:
BlueBSH 07-25-2010 07:16 PM
That's what I did in the past but realized I had a compound miter saw (not idea how I never noticed that before......) anyways... thought it would be easier with the compound miter... but seems like its worse...
Tom Struble 07-25-2010 07:28 PM
you use the compound only when the moulding is layed flat on the miter box
BlueBSH 07-26-2010 06:13 AM
yes that is what I was doing with the compound miter, I only had it upright when it was a normal miter... but when it was flat it seemed like I needed angles like 31 degrees to get the same cut that I got with the normal 45 degree upright upside down cut
unlvrebel 07-26-2010 11:21 AM
Use the ole tried and true method described above. I have a compound miter saw myself and have very rarely used the second angle. Just too easy to do crown the other way.
