Crown - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2011, 04:00 PM   #1
Experienced
Naz1298's Avatar
Crown
How difficult is it to put crown on a sloped ceiling
Naz1298 is offline   Reply With Quote
Old 07-27-2011, 05:04 PM   #2
Rewards Points: 5,336
It's made to be secured to a 90 degree application, sitting tight to both surfaces. Applied to a sloped ceiling would require some blocking behind it unless you were laying it flat on the surface.
Ron
B. Franklin 1759
Old 07-27-2011, 06:37 PM   #3
Experienced
Naz1298's Avatar
What about a slope like this...
Old 07-27-2011, 06:59 PM   #4
The wall and the ceiling are at 90 degrees, except the right side of the picture. Making the transition up the roof slope should be fun. It's the transitions in planes that will give you pause.
The standard installs at the 90 degree places will kick out from the wall much more then where the sloped ceiling contacts the wall.
The trick will be to make a smooth transition as you go up the wall.
Ron
B. Franklin 1759
Old 07-27-2011, 07:31 PM   #5
Experienced
Naz1298's Avatar
So basically no easy way except trial and error. Kewl sounds like fun. Thanks for the info.
Old 07-27-2011, 07:52 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 184
Here ya go.
Crown moulding with a vaulted ceiling?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-27-2011, 08:27 PM   #7
Experienced
Naz1298's Avatar
Thanks Jiju
The Following User Says Thank You to Naz1298 For This Useful Post:
BigJim (07-27-2011)
Crown moulding and drywall (to tape or not to tape?) gspck Drywall & Plaster 4 11-10-2010 03:41 PM
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 10:40 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
