Cross Bracing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-30-2007, 11:48 AM   #1
cross bracing
I have a free standing entaining area 9mx6m.Timber post are 3m apart what is the best bracing to use to stop the swaying.Regards Dave
justfun is offline   Reply With Quote
Old 04-30-2007, 01:02 PM   #2
Rewards Points: 1,088
You can probalby use furring strips or cables.
handy man88 is offline   Reply With Quote
Old 04-30-2007, 03:08 PM   #3
concretemasonry's Avatar
Rewards Points: 2,578
cross bracing
You can use firring strips if you just want to cross-brace between joists.
To brace the structure agaist swaying , put diagonals at 45 degrees between the beams and the posts at the corner posts. the further down the post or the more corners you brace, the steadier it will be. For appearance, you may want to use braces the same size as the posts.
Diagonal cables from the bottom of one post to the top of another would also work, but you would need then to "criss-cross". This can cut off access, but would help if you want to train some vegitation in one or more bays in each direction.
Apparently, you do not have the posts into the ground far enough to provide rigidity.
concretemasonry is offline   Reply With Quote
Replace Iron with PVC on DWV cross froddan Plumbing 2 06-15-2007 05:05 PM
X Brace, Cross Brace Removing ejensen1 Building & Construction 2 04-16-2007 06:08 AM
rafter thrust/cathedral ceilings godin Carpentry 7 07-09-2006 07:44 PM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 05:35 PM
