Crooked Fence - Grrrrrr - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-04-2007, 06:06 PM   #1
Alright, so I rented an auger and had someone help me dig the holes and cement 10 galvanized posts into the ground for my fence. We tied a string from one end to the other when we started so we can use it as a straight line reference.
Well, the string must have loosen up while we were working because the fence is now crooked. It was to meet up with an existing fence but it is way off. I get to delete 'replace fence' from my list and add 'replace fence, again'.
Anybody have any ideas of how to straighten the posts? The only thing I can think of is remove the rails with the pickets attached(remove pickets that connect 2 rails) and use shovel to dig a vertical hole alongside the cement. With some help raise the post just enough to slide it into correct position. This time making sure that the string is nice and tight.
Any other ideas?
Dallas is offline   Reply With Quote
Old 12-04-2007, 07:18 PM   #2
Your idea of moving the posts wouldn't be too bad, if it is only one or two posts.
If the posts are off sufficiently to allow for it, you could cut off the posts and install new ones next to or in front of them. Either way, you are in for some additional work.
Handyman50 is offline   Reply With Quote
"T"-ing off of neighbours' fence? curls00 Carpentry 6 01-10-2009 04:39 PM
Height of Fence = Height of Posts Necessary Dallas Building & Construction 2 11-05-2007 10:47 AM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
Fence Bid - A Rip-Off ??? kenziekiss Building & Construction 7 12-31-2006 08:12 PM
Constructing a New Fence With Neighbor Kwak Building & Construction 2 10-03-2006 02:41 AM
