Cripple Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 08:08 AM   #1
Cripple Wall
I'm expanding my existing garage out the back. When building my temporary cripple wall to support my roof trusses prior to removing 11' of the back wall and installing the new header, can I space the cripple wall studs 24" o.c. or should I space them 16" o.c.? There's only attic space above, no second story of the house to support. Thanks.
Jim Hart is offline   Reply With Quote
Old 03-11-2009, 10:11 AM   #2
Registered User
Termite's Avatar
If it is temporary I don't think it'll be a problem. Just make sure that you have meat on top to prevent the top plate of the temporary wall from sagging between the studs under the load. Two plates would be an absolute minimum with 24"oc stud spacing, even for a temporary wall.
Old 03-11-2009, 11:40 AM   #3
Thanks, I'll use a double top plate with studs 24" o.c. and try to line up the studs directly below the trusses.
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Replace Cripple Wall to Raise Foundation? casey_wa Building & Construction 1 08-04-2007 04:32 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
