Creating A Vaulted Ceiling For Patio - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-26-2011, 07:49 PM   #1
Creating a vaulted ceiling for patio
I just purchased a house that has a detached outdoor patio that has a vaulted roof (shingled) and a low flat ceiling. I thought that it would be much nicer to remove the flat ceiling and possibly create a vaulted ceiling or go with the exposed beam look. I have removed one of the 4X8 ceiling boards to see what it looks like above. There is one main large beam running dow the center of the ceiling with metal brackets on it and then long narrow beams running from the main beam to the edge of the covering every 2 feet that the ceiling boards are nailed to. Based on the attached pictures what is necessary to get rid of the low beams and create a much nicer vaulted ceiling? I also thought about just nailing plywood or hardy boards to the existing ceiling if the vaulted ceiling was too much of a hassle, but that would lower the ceiling further (although it would definately be a cleaner look than the roofing boards that are there now. Thanks in advance for your help.
Creating a vaulted ceiling for patio-img_0490.jpg   Creating a vaulted ceiling for patio-img_0491.jpg   Creating a vaulted ceiling for patio-img_0493.jpg   Creating a vaulted ceiling for patio-img_0494.jpg   Creating a vaulted ceiling for patio-img_0496.jpg
tcaesar1 is offline   Reply With Quote
Old 04-26-2011, 10:30 PM   #2
Registered User
Rewards Points: 526
Do not remove them. The main girder beam in the center is supporting and tying the ceiling joists together, keeping the roof pitched and together. You could contact a Structural Engineer to size the beam for the roof/ceiling loads as well as any additional snow loads for your area.
Welcome to the forum!
Gary
Installing Knotty pine to vaulted ceiling atonkennedy Remodeling 1 09-17-2010 08:03 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Vaulted Ceiling - (Pictures included) How to do it? peabodyn Remodeling 7 03-29-2009 11:18 AM
Insulation of a Vaulted (Cathedral) Ceiling cbeingessner Building & Construction 2 01-13-2008 11:19 PM
Vaulted Ceiling, faux wood beam, ceiling fan? zel Electrical 9 07-13-2007 05:30 PM
