| View Poll Results: Would you attempt this project yourself? | |||
| Yes |
2 | 33.33% |
| No |
4 | 66.67% |
| Voters: 6. This poll is closed | |||
#1 |
Creating a Trey Ceiling in the Master Bedroom
As the average handyman, I'm wanting to add a Trey ceiling in the master bedroom. Other than being time comsuming, is this to much for the average handyman, any advice on the best way to do it. Any suggestions? I will be greatful for any positive insight one has to offer.
#2 |
What is a trey ceiling?
#3 |
Multi level ceiling?
#4 |
BUILDER / REMODELING CONT
for an average handy man it could be a challenge, I do not know what your skill levels are. what type of roof design is over the master bedroom now, Gable, Hip??. is there any skylights over the bedroom.
how high do you want the flat part of the tray to be. I keep them around 16"- 24" from the top plate. the first thing you must do is remove all the ceiling covering and insulation from the ceiling. relocate any electrical wiring that could be running across the ceiling. This could be one big pain in the a$$ if all your feeds come across going to the panel. Build a wall over your bearing bedroom partition that the ceiling beams are resting on. install the studs so they are on the other side of the ceiling joists from the other room. this way when you remove the bedroom ceiling joists they will not be in the way. the wall your building should rest under the existing roof rafters. which will help support the outside wall from thrusting outward over time. I then install blocking between the rafters over the side partition wall,install a top plate plumbed up from that wall and install studs. make sure the studs are in line with the side gable studs or roof rafters if its a hip roof. now mark the height of your ceiling along the wall you built over the bearing partition.(snap a horizontal caulk line. from end to end. then level to the outside wall and mark along side of the rafters that are resting on the outside plate. install your ceiling along side of these marks. on the sides of the room where the short rafters are going to run and get connected to the flat, make sure you double these end ceiling beams up. find the pitch of the rafter on the outside wall and the length and make your new short rafters the same so they will mount to the double ceiling joist. Make sure the double ceiling joist are running parallel to the side walls. and check for squareness. once the ceiling joists are installed run a few across the top of these connecting the gable studs to the studs you installed on the side partition wall. this will help tie in the side walls . after you remove the strong backs from the old ceiling.then make your ceiling hip rafters to fit in the outside corners. I use a bevel gauge and a ruler. Install blocking and any nailers that are required. the rest you should be able to do. Just make sure you install insulation baffles under the outside roof rafters be fore you insulate. Good Luck. |
#5 |
You didn't say what size you were talking about, but if you have the height, instead of going up - go down
#6 | |
Framing Contractor
Creating a Trey Ceiling in the Master BedroomQuote:
Joe Carola |
#7 |
It all depends on what you have now...as to what to do and how hard it might be. Arch or structural engr is always best... if you can post more info and pics...this could be simple..or ill advised.
floor to ceiling at walls... how high? Peak and or current ceiling layout? treys ceilings can be Kool and add visual impact to the space... can be a pain or simple.. we need more info to help you. |
| Display Modes | |
| Height of a ceiling fan with a trey ceiling? | Bacardi 151 | Electrical | 7 | 09-08-2010 11:55 AM |
| Old ceiling replacement | idsp | General Discussion | 12 | 07-25-2009 11:48 AM |
| Condo Drop Ceiling transformed into a Lighted Trey Ceiling | Sir MixAlot | Project Showcase | 14 | 06-28-2008 08:58 PM |
| Moved ceiling light in bedroom to center, now trips breaker | blthomas | Electrical | 18 | 01-24-2008 05:29 PM |
| Turning a Guest Bedroom into a Master Bath | BbAaSsSs | Remodeling | 18 | 03-10-2007 06:03 PM |
