Creating A Soundproof Wall Question - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-22-2009, 03:18 PM   #16
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the hat channel i suggested is to be used on the new temp wall in addition to other items suggested here. it will increase the sound isolation.
Old 02-22-2009, 05:53 PM   #17
I'll look into the hat channel. I called quietrock to find the nearest dealer to me but their office was closed. I'll try tommorrow. Home Depot does have it and there aren't too many lumber areas around. I read somewhere that one sheet of quiet rock is equivalent to the sound deadening of 8 sheets of sheetrock..
acyate is offline   Reply With Quote
Old 02-22-2009, 08:07 PM   #18
Another product you may want to look at - used for ceiling/wall or floor applications.
http://www.homasote.com/products/440-Soundbarrier.aspx
Rivethead is offline   Reply With Quote
Old 02-23-2009, 05:42 AM   #19
Remodeling Contractor
hat channel has many installation issues that have proven to short circuit the effectiveness for sound deadening. Best to not bother with it as a DIYer. Check out the details here. http://www.quietsolution.com/Cost_Be..._vs_QR_scn.pdf It does add STC to a wall (50) But not the 72 that the new soundproofing drywall will add. And since you are making an isolated wall, you have not direct contact transmission here to deal with, which is what the hat channel is compensating for.
Old 02-23-2009, 09:10 PM   #20
nap
You talking to me?
nap's Avatar
I'll accept that. I can see the problems a DIY'er (especially) could cause.
I still believe it would be beneficial (even with a freestanding wall since you would still be isolating the rock from the studs, which are still going to transmit sound from the other side although not as much as a rocked wall) but due to the great possibility of misinstallation, it would be likely less effective than intended.
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Thru wall vent question phillyexplorer HVAC 5 10-11-2008 09:50 PM
Removal of interior wall Bobb G Remodeling 4 09-15-2008 01:30 PM
knee wall question jscholl411 Building & Construction 7 10-10-2007 12:30 PM
Off the wall question Rick Bruner Plumbing 2 05-13-2007 05:46 PM
