Creating Slope With Hardy Backer Board. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 03:12 PM   #1
Creating slope with Hardy Backer board.
Can Hardy backer board be installed on a walking surface, with furring strips to create slope? Both 1/2" and 1/4" thicknesses, if ok, what would the maximum span between furring strips for each thickness?
This is an exterior deck that is currently flat, we want to create slope with the Hardy backer board, we will then Waterproof before a finish pour of concrete?
gkrische is offline   Reply With Quote
Old 01-23-2013, 04:25 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
Since concrete wants to self level on the surface wouldn't you have to slope the concrete whether your substrate is sloped or flat?
brockmiera is offline   Reply With Quote
Old 01-23-2013, 04:54 PM   #3
Rewards Points: 3,130
That's a pretty wacky idea. I don't think it would work.
Old 01-23-2013, 05:40 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
Ayuh,... The concrete pour will take care of any pitch problems in, 'n by itself....
Skip the hardy board, 'n pour the concrete, 'n finish it to whatever grade ya want...
Old 01-23-2013, 06:10 PM   #5
Rewards Points: 12,824
It has 0 strenght, can not be laid with any gap under it or it will just snap off, can not just be installed directly over a slab.
All it's made for it to give the tile something to bond to.
shower rebuild - need help with backer board & green board johndoe12345 Tiling, ceramics, marble 2 11-27-2011 02:16 PM
Hardie backer board textured with thin set wildwort Tiling, ceramics, marble 14 11-21-2011 11:01 AM
Backer Board Around Tub Deteriorated. devnull88 Plumbing 2 05-18-2011 04:56 PM
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
