Creating Open Floor Plan - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 10:53 AM   #1
Hi guys,
I want to renovate our kitchen/living room in my split-level home. I want to have a completly open floor plan, and am wondering what I need to do to do it. I included some photos of our situation. I do not know if any of the existing area we want to remove is a support wall, and if so, can I install a laminate beam across the span of the the attic to reinforce instead? Also, we want to have the option to build another level above in future years. So I believe we would need to change out the 2x6 joists for atleast 2x10s. Not sure how to do that with the current 2x6 joist running completly from one side to the other right now.
Thanks,
Kevin
Kitchen View Area to be removed
Another Angle with Joist Orientation
View From the Attic - 2x6s for Joints with a 2x12 spanning some but not all
Other side of room
View from Basement
Supports in Crawlspace underneath the kitchen
Further back view of crawlspace with middle support
kevin327 is offline   Reply With Quote
Old 12-18-2010, 11:22 AM   #2
Rewards Points: 5,336
Somewhere in that structure is a load bearing wall. How you would compensate for the wall removed would be determined by an onsite inspection by a competant individual. This person would also engineer a beam for the span and the loads involved.
Internet guesses have no merit.
Ron
Old 12-18-2010, 12:10 PM   #3
Civil Engineer
Rewards Points: 4,790
You are undertaking a relatively complex project, complex because you not only need to compensate for removal of bearing walls, but you have a long term program of adding another story. I recommend you hire an architect to prepare the design. They will likely work with a structural engineer to size the specific beams, develop a plan which can be implemented in steps, and will meet all code requirements.
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 01:17 PM
Open Stairs in Basement ngerhard Building & Construction 4 07-10-2009 06:30 PM
Which should open first GFCI or breaker jamiedolan Electrical 14 01-19-2009 03:03 PM
garage door open light deck hand Electrical 3 01-22-2008 08:29 AM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 10:46 PM
