Creating A French Drain - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 11:47 AM   #1
ks2
creating a french drain
Hello
I have a 90 foot long 1958 home built on a slab. The lay of the land is such that as ground water flows from rain water it flows against the back of the home. Consequently when ever there is the slightest mositure in the ground our slab in the garage is completely covered in moisture and I can only assume that the same is occuring in the home.
From my readings, it sounds as if a french drain is in order.
The question is if it is permissable to drain from only one end of the drain. We have a large concrete drive that extends from one end of the home that will not allow me to place the drain to a low lying area.
Any help will be appreciated
Ken
ks2 is offline   Reply With Quote
Old 03-07-2009, 12:07 PM   #2
Old School
Willie T's Avatar
Most French Drains I've installed drained from only one end. Sometimes, across a garage door, we'd split the slope, but only because the driveway was crowned, left and right.
Willie T
Old 03-07-2009, 12:15 PM   #3
Remodeling Contractor
No issues as long as your still maintain some pitch on the drain pipe. This is an expensive project. Be sure to wrap commercial grade landscaping cloth to keep the drain pipe and the gravel clear. If you need to run to a low area, end the drain in a large dry well.
French Drain Solution? Any Help Would Be Great! gregt848 General DIY Discussions 2 08-01-2008 09:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Determining existance of French Drain cmarti02 Plumbing 2 11-07-2007 06:51 PM
French drain question Tom Fan Landscaping & Lawn Care 3 06-04-2007 06:16 PM
