Creating A Floor For A Small Pool | Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 03:51 PM   #1
Creating a floor for a small pool | question
I dug a hole in my backyard about 1.5mX1.5m currently about half a meter depth, hoping to make it something like meter and a half.
I intend to use some concrete as a floor and to make some plaster in order to prevent the water from leaking.
My intention is to cover the walls and floor of the hole with concrete and a thick layer of plaster on it
I need a recipe for plaster - how to make it and how to use it.
thanks ahead :-)
pictures of the hole here:
http://img28.imageshack.us/gal.php?g=sdc10234m.jpg
asafyi is offline   Reply With Quote
Old 07-17-2010, 10:56 PM   #2
jules4's Avatar
"Plaster" as in the stuff you put on walls? That will just disintegrate in water.
You could coat the concrete with clay to prevent leaks (or skip the concrete and just use a nice thick layer of clay).
Or, if you need something that gives a hard, plaster-like surface you could coat your concrete with Tegraproof.
You could also make concrete that is waterproof all by itself, as described here: waterproof ferrocement.
jules4 is offline   Reply With Quote
Old 07-17-2010, 11:42 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
=jules4;471182]"Plaster" as in the stuff you put on walls? That will just disintegrate in water.
no it won't, if you use the right kind of plaster. Concrete pools have been using plaster topcoats for decades.
one plaster I was looking into for another project (bathtub) is tadelekt. Don't know if it be the best plaster for the OP but there are waterproof plasters out there.
asafyi; what are you using this for?
Old 07-18-2010, 01:13 PM   #4
Rewards Points: 502
have you researched pool building? its not just dig a hole, add water.
you might consider a vynil liner. they are cheaper, especialy if you go with a standard size.
forresth is offline   Reply With Quote
Old 07-18-2010, 01:46 PM   #5
DIY staff
Rewards Points: 7,174
Rubber roofing is a standard liner---they hold up for years.
Old 07-18-2010, 03:06 PM   #6
usage of the pond
I use it for dipping about a few times a week.
Old 07-18-2010, 04:48 PM   #7
If the ground in your area freezes and thaws with the seasons your pool walls will need addt'l strength.
Old 07-18-2010, 06:24 PM   #8
nap
You talking to me?
nap's Avatar
maybe your location might be critical here. Not too many people ask how to make plaster.
Pool Motor Question...Please Help! gmcf2004 Electrical 13 06-01-2009 07:34 PM
Creating a soundproof wall question acyate Building & Construction 19 02-23-2009 09:10 PM
Inground Vinyl Pool Question intofire Landscaping & Lawn Care 0 09-11-2008 10:34 AM
Pool Pump Wiring mpdive Electrical 17 06-15-2008 07:30 PM
foundation question for building a small cabin TNeat Building & Construction 3 08-01-2007 06:08 PM
