Create My Own Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 10:15 AM   #1
create my own siding
I'm considering the idea of taking $.50 pieces of 2"x4"x4' or 2"x6"x4' pine and ripping it vertically into planks that I can use as siding to cover the outside of a playhouse. I'm trying to do this the cheapest way I can that is sturdy, looks pretty good, and will last. Any thoughts on the feasibility of this idea of creating my own siding? Thanks-
jjjeno is offline   Reply With Quote
Old 04-13-2011, 06:17 PM   #2
Rewards Points: 4,796
howzabout find a roofing company in town that's replacing a roof,,, you can get ALL the used shingles you want for FREE personally i think you're spinning your wheels
Old 04-13-2011, 06:44 PM   #3
Not so new
12penny's Avatar
Rewards Points: 520
...yeah really. Just pick a siding and go with it.
12penny is offline   Reply With Quote
Old 04-14-2011, 01:19 AM   #4
Are you shooting for board and batten siding?
2x4 battens (5/8ths by 3.5") and 2x6 boards?
How do you plan on ripping the 2x4's
Most homeowner grade table saws struggle to make a full depth cut through a 2x4.
It's feasable but not very nice on the saw and you'll end up with an inferior product. Studs aren't exactly weather resistant.
I think you'll have much better success looking for some free siding scraps on craigslist.
Robert C1 is offline   Reply With Quote
Old 04-14-2011, 03:02 AM   #5
own siding
I thinking about,Siding and Home Values -- HGTV recently aired their top home improvement ROI projects. Home siding topped the list, adding, on average, the cost of the project to the value of your home.
vipin is offline   Reply With Quote
Old 04-14-2011, 06:42 AM   #6
Gymschu's Avatar
Rewards Points: 1,024
Vinyl is final.
Gymschu is online now   Reply With Quote
Old 04-14-2011, 07:30 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
You'll need a resaw band saw or a contractor grade table saw for this little endeavor.
As long as you have the time and patience go for it.
Vertical or horizontal ?
Spruce? Pine? Redwood? Cypress?
Pics...please
tcleve4911 is offline   Reply With Quote
Old 04-14-2011, 07:33 AM   #8
kwikfishron's Avatar
Rewards Points: 1,002
Originally Posted by Gymschu View Post
Vinyl is final.
What?
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Gary in WA (04-14-2011)
Old 04-16-2011, 10:10 PM   #9
Knucklez's Avatar
Rewards Points: 942
board & batten?
lodge pole pine is used because you can get good long pieces 16' easily. the knots are all injected with hardener. the backside of the boards should have two parallel 1/2" wide 1/4" deep cove groved out of it so that air can travel up the backside of the board to dry it out. the boards are each sprayed with high grade exterior paint and the face is sprayed a second time.
as you install board and batten it is important to know how your boards will shrink and expand through the seasons with respect to your nailing pattern. the idea here is to not let your boards split. if you have to butt two boards together to get the length you require on the wall, the ends should be mitered to 45deg and installed such that the water does not get trapped there but rather just gravity drains out.
wrap house in tyvec. strap house horizontally with 1x3 spruce.
use stainless steel ring shanked nails. nails must penetrate 1" into solid wood (which is your strap + house framing, the chip board house sheathing doesn't count). you'll need a lot of them & two different lengths
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 10:07 PM
create positive slope when siding is at grade? pfisch Building & Construction 4 03-22-2009 09:18 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
