12-15-2010, 05:22 PM
#16
Crawlspace Wall Insulation
Originally Posted by ConcreteTreat
Anytime, Earnie. :-)
I'm also very on board with the commercial dehumidifier -- I recommend the SaniDry or a Santa Fe model.
Concrete Treat
Concrete Sealer
I can't offer much except to 2nd the dehumidifier - I've been running the SantaFe for going on 3 years 24/7 and it has done an amazing job with very minimal additional cost (electrical) in an 1100 sq ft sealed crawl space. Fan runs 24/7 filtering the air down there and dehu kicks in as required. No regrets on the up front cost. fwiw.....
12-17-2010, 08:21 AM
#17
Up to two inches of unfaced extruded polystyrene (R-10), four inches of unfaced expanded polystyrene (R-15), Blue or pink rigid foam boards three inches of closed cell medium density spray polyurethane foam (R-18) and ten inches of open cell low density spray foam (R-35) meet these permeability requirements.
In crawlspaces where the insulation material will need to be covered by a fire/ignition barrier, it may be acceptable to use fire-rated foil-faced insulations. However, such requires careful attention to supplemental moisture management strategies. With vapor impermeable facings on interior insulation, it is possible that water may accumulate between the insulation facing and the inside surface of the foundation wall. The airtightness of the assembly is, therefore, extremely important to prevent the exchange of air between this damp interface and anywhere else in the building.
This section has me confused. Per my building code, I need the foam covered by a fire rated material. Fire rated material can also be drywall and some bat insulations. But why would I want to cover foam board insulation with drywall or more insulation in a crawlspace? Thermax has 1.25 mil foil on one side and 0.9 mil foil on the other side. This exceeds the 0.41 mil thickness required by R314.5.4.6 (Corrosion-resistant steel having a base metal thickness of 0.016 inch (0.41 mil)).
- Is aluminum foil equal to "corrosion-resistant steel"? Some is I believe, it depends on the thickness of the aluminum, but importantly what is under it - the foam board. Some foam boards are quicker to combust thus more toxic. Can you provide a code reference which states they are equal?
- Since I also need about 5 inches of inspection area on the block wall to check for termite activity, how would this affect the air tightness or moisture accumulating behind the foam per the last sentence in above BSC quote? That's good question.....if I understand, you would need something that is removeable/replaceable to inspect. So, 8' x 5" sections of foam board taped at the seams? I have no idea. Don't you just enjoy how the government makes demands but provides no help in meeting those demands! My thought was to leave the five inch area uncovered, no foam board, for easy inspection. But would that actually affect the sealing of the crawlspace?
- Can anyone explain what R314.6 states about an ignition barrier not being needed if the foam has been tested? Some or most commercial applied spray foams has a fire retardent mixed in with the foam, while it is being applied. This is referenced in R314.5.4 Can you provide a quote from the actual code reference?
All of the information I have read shows companies installing up to 20 mil plastic sheet to the crawlspace floor and up the block walls. That is a vapor barrier. Foam board with a foil facing is a vapor barrier. What's the difference?
What are supplemental moisture management stratigies? Won't water accumulate on the inside of a 20 mil plastic sheet just like it will accumulate on the inside of a foil faced foam board?
12-17-2010, 07:07 PM
#18
A barrier between the foam board and fire.
Best to check with the manufacturers and see what they say.
I think it greatly would! .....warm - cold = condensation. I would think that they would want to have it at the top portion of the foundation to the sill plate, and to me that's the most important area to seal..... and when was the last time you had your 5" area inspected?
Check with your local building dept. and see if they recommend an acceptable company or vise versa. Only certain types are acceptable in lieu of a (15 minute?) thermal barrier. It varies, depending on where you are located.
The rigid foam board will give you an R value, as well as a vapor barrier, if properly sealed.
Sounds to me like...... if you have moisture problems, you would need a way of getting rid of the moisture, as the board will not. If heavy moisture is coming through the foundation, you may need a water proof membrane on the exterior walls to seal them up or a french drain (or similar) or even something as simple as grading the ground away from the foundation.
I think that's a good assumption. That's why it needs to be 'managed' so it doesn't get to that point.
12-17-2010, 09:05 PM
#19
Moderator
The way I understand is a conditioned crawlspace- exhaust outlet fan, conditioned supply air, air tight, etc., is treated as a basement for moisture control. This will help: http://www.swinter.com/news/document...sulSystems.pdf with the foil faced. If completely covered, you need additional interior french drain to manage the moisture through the concrete wall, stopping and condensing on the f.f foam board, run down, remove to another collection/disposal area.
The thicker insulation board is to limit the escaping heat through the below grade concrete wall: http://www.quadlock.com/technical_li...Insulation.pdf
Why the R-10?: http://www.buildingfoundation.umn.ed...timum-main.htm
Gary
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
12-17-2010, 09:25 PM
#20
Very interesting links Gary.
It's surprising the heat loss through the concrete walls......very informative!
12-17-2010, 09:44 PM
#21
Moderator
I found this also, start by backing up a few pages: http://books.google.com/books?id=_pc...page&q&f=false
You may want to tape the edges and don’t make holes in the Polyiso for water: http://docs.google.com/viewer?a=v&q=...4EyM707m0gPdXQ
Gary
12-17-2010, 10:00 PM
#22
Gary, I was writing when you posted your last info.
Thanks for the replies guys.
Ok, just to re-clarify.
This is a crawlspace, approximately three feet high. Inside of crawlspace is concrete block but the exterior is 4" decorative red brick. The dirt ground inside crawlspace is above the exterior grade. Not by much, but higher. I "see" no evidence of moisture on the inside concrete blocks.
I want/need to provide a better environment for the house and HVAC air handler and ducting which are in the crawlspace.
Currently, the crawlspace only has minimum code required 6 mil poly on the ground. I want to upgrade the poly to at least 12 mil and insulate the block walls which are visible above ground.
How is a homeowner supposed to seal and insulate a crawlspace but still make it possible to see termite tunnels before they get to the rim joist? I don't have a concrete floor like you would in a full basement, its dirt.
It's my understanding to keep the top 5 inches of concrete block uncovered to provide a visible band around the perimeter. Makes it very easy to check for termite activity when under the house.
So, anyone have ideas how to correctly install vapor barrier and foil faced foam board insulation up the concrete blocks?
This question will be asked at the building department too.
12-17-2010, 10:20 PM
#23
Another point to note.....if the attic isn't properly insulated and vented, (a good flow through the sofits up) the air that is needed for the roof vents, is being pulled up from the living area.
The stale, crawl space air is then being pulled up to replace the air in the living area.
12-17-2010, 10:26 PM
#24
Good point Rick.
I have that one covered. Attic is supplied with air from plastic soffit vents on both sides of the house. Plastic baffels are in the roof cavities to keep insulation from blocking air flow. Ridge vent all along the roof.
12-18-2010, 04:01 AM
#25
'per building code' is only the MINIMUM standards to which anything must adhere/pass,,, eg, how many plumbers would have shark's grip fittings in their home ? nor would i allow toe drain & dampproofing to ONLY Meet code in OUR home ?
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders ! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
12-18-2010, 11:07 AM
#26
I think you have to find out what your local codes require. It's much easier to work back from there, and maybe even improve on it.
They will vary by location ...... eg. where I am, we have no need for a termite 'window'.
Here's a few sites with a bit more info, if you haven't come accross them already.....
http://www.crawl-space.com/
http://www.crawl-space.com/PDF/USDOE_techfactsheet.pdf
Here's a paragraph from this website
http://www.ornl.gov/sci/roofs+walls/insulation/ins_06.html
When a fiberglass blanket is used to insulate the walls of an unventilated crawlspace, it is sometimes necessary to attach wood furring strips to the walls by nailing or bonding. The insulation can then be stapled or tacked into place. Alternatively, the insulation can be fastened to the sill plate and draped down the wall. You should continue the insulation over the floor of the crawl space for about two feet on top of the required ground vapor retarder. Because the insulation will be exposed, be sure to use either an unfaced product or one with the appropriate flame spread rating. When rigid foam insulation boards are used to insulate the walls of an unventilated crawlspace, they can be bonded to the wall using recommended adhesives. Because the insulation will be exposed, be sure to check the local fire codes and the flame-spread rating of the insulation product. If you live in an area prone to termite damage, check with a pest control professional to see if you need to provide for termite inspections
In the above, if you have an approved insulation blanket, it may be appropriate to be able to lift it to check for termites.
12-18-2010, 02:29 PM
#27
Rick,
Thank you for the link to crawl-space.com. That's the best site I have seen to describe how to seal the crawlspace. I'll take those .pdf files with me when I visit the building department.
From what I have looked at so far, the key may be to cover the concrete block but still leave the 5" bug inspection area. Next cover the ground and lap the vapor barrier up and over the block wall vapor barrier. Finally, install the foam board on top of the block wall vapor barrier.
All subject to the government of course.
10-22-2012, 05:09 PM
#28
Rick,
I have almost the exact same crawl space design. Can you tell me what you did exactly. The termite inspection issue is one I am particularly interested in.
Jim
10-23-2012, 07:59 PM
#29
Jim,
You probably need to direct your question to Ernie, and find out how he made out.
Sorry, I have no experience with the termites.
Rick
Originally Posted by a6spot
Rick,
Jim
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
