Old 02-10-2010, 05:37 PM   #1
Crawlspace Vents?
I live near Williamsburg on the Virginia Peninsula. This year has been unusually cold with temperatures at or below freezing for much of January and February.
Our home is a 3-story 3,800 SF structure with a crawlspace. There are approximately a dozen vents that help vent the crawlspace area. My question is should I close the crawlspace vents during the cold winter months?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 02-10-2010, 06:04 PM   #2
Crawlspace Vents?
as i understand, current code in ga calls for unvented crawl spaces,,, we typically install 20mm vapor barrier & humidistat controll'd exhaust fans ( on 1 side )
itsreallyconc is offline   Reply With Quote
Old 02-10-2010, 06:41 PM   #3
Crawlspace Vents?
IN eastern Washington we use vents (1 square foot of vent per 300 square feet of house). It gets cold here in the winter and we close the vents. But humidity can be a problem in the summer so they need to be open then.
warnerww is offline   Reply With Quote
Old 02-11-2010, 03:58 AM   #4
Crawlspace Vents?
Has anyone tried installing automatic vents?
http://heating-and-cooling.hardwares...ign=googlebase
Old 02-11-2010, 07:41 AM   #5
General Contractor
Crawlspace Vents?
Vents should be installed at a ratio of 1 SQFT of vent per 150 SQFT of under floor space, with one vent located within 3' of each corner. Reference section R408.1 and R408.2 of the IRC building codes for more information. You should close the vents when the temperatures drop below 64 degrees. Automatic vents are a great product and are easy to install.
ARI001 is offline   Reply With Quote
ridge vents vs. box vents vs. turbine vents redaws Roofing 12 03-12-2012 10:48 PM
Crawlspace Moisture - Serious Problem PaoloM General Discussion 11 12-15-2009 02:35 PM
Closing Crawlspace Vents -- temporarily Steve Burke General Discussion 7 12-09-2009 08:03 AM
Insulating an unheated crawlspace indignatz Building & Construction 7 10-28-2009 07:29 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 08:49 AM
