Crawlspace Issues - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2013, 10:39 AM   #1
Rewards Points: 168
crawlspace issues
What is the best way to get the crawlspace area aired out.there is plastic down and condensation still present with vents open.ac is not in operation .
Vents are all open .it is a bit humid out though .
Any info is appreciated .
hidden 1 is offline   Reply With Quote
Old 06-20-2013, 01:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,862
Is the vapor barrier on the floor seal to the stemwall?
If there's enough relative humidity in the air and the ground temperature is cool enough you will get condensation on top of the plastic regardless of what you do.
The only way to effectively eliminate that would be to eliminate the source of the moisture by sealing up the crawlspace and insulating the stemwall and converting it to a conditioned crawlspace
The Following User Says Thank You to Windows on Wash For This Useful Post:
Dave Sal (06-21-2013)
Old 06-21-2013, 03:17 PM   #3
Rewards Points: 664
I have this problem too. What is a stemwall and please define "conditioned crawlspace." Thank you.
crescere is offline   Reply With Quote
Old 06-21-2013, 05:17 PM   #4
Here you'll find much information, including a lot of instrumented studies, and ways to remediate problems:
http://www.crawlspaces.org/
RoyalAcresRod is offline   Reply With Quote
Old 06-22-2013, 10:12 AM   #5
Starting searching the "Insulation" section of the forum and you will get all the information you would ever need there as well.
Old 06-24-2013, 05:00 PM   #6
Rewards Points: 664
How do I insulate the stemwall? Styrofoam panels?
Old 06-25-2013, 05:14 AM   #7
Rewards Points: 4,534
we run exhaust fans on 1 side of the space,,, vents are avail w/built-in elec fans,,, control them w/humidistats for automatic use
Old 06-25-2013, 09:14 AM   #8
Craw space fans work in some parts of the country. In other areas, introducing warm air into a cooler crawl space causes the moisture in the air to condense, wetting the surfaces in the crawl space and making things much worse.
Although a lot of work, closing (and sometimes conditioning) the crawl space is often the best answer ... depending on the prevailing climate where the home is located.
The Following 2 Users Say Thank You to RoyalAcresRod For This Useful Post:
Dave Sal (07-02-2013), Gary in WA (06-28-2013)
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 08:03 AM
The Great Crawlspace Challenge casualfc Building & Construction 4 09-19-2011 04:34 PM
Crawlspace moisture---So much conflicting information Giles Building & Construction 2 08-27-2011 11:35 AM
Furnace is in attic, I want to move it because of efficiency issues... SimonSezz HVAC 1 01-22-2011 07:23 PM
Spray foam - code issues? upinsmoke Building & Construction 1 05-10-2010 08:47 PM
